emergency help im off the freeway on my sidekick
my car just made this grinding noise n my car just died, my friend tried jumping me and i popped the clutch and still no start. my starter wont even crank some1 please help mee!!!
Are your other electronics working? That happened to me before. Try checking your grounds and if you have sand paper or a tooth brush, try cleaning up the battery terminals.
the terminals are all clean, and now im at home tryna figure out whats up with my prelude. im not quite sure which grounds i should chek all the things off the starter seems tightened
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ninja »</TD></TR><TR><TD CLASS="quote">could it be his ignition switch?</TD></TR></TABLE>I doubt it.. when my ignition switch gave out, the car worked fine, and when I turned it off, and came back to turn it on, it wouldn't start, it'd just crank up and die immediately.
sorry car problems are a bitch and all
but this is funny
why the hell are you trying to diagnose a problem, road-side?
do you intend on installing a brand new timing belt, starter, etc. on the side of the road with your emergency blinkers on?
but this is funny
do u hear ur fuel pump? my car does this sometimes when im trying to start it in the morning. turn on ur headlights...are they bright? if so, crank the key, turn on the headlights, then off, then it might start. has worked for me before...dont ask me why.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">Bah.. call a tow truck you tool</TD></TR></TABLE>
Bah...He said he was at home already...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeSH »</TD></TR><TR><TD CLASS="quote">
Bah...He said he was at home already...</TD></TR></TABLE>
I didnt read that where did it say that???? Tool...
I didnt read that where did it say that???? Tool...</TD></TR></TABLE>
Right here...TOOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef.love »</TD></TR><TR><TD CLASS="quote">the terminals are all clean, and now im at home tryna figure out whats up with my prelude. im not quite sure which grounds i should chek all the things off the starter seems tightened</TD></TR></TABLE>
Right here...TOOL
if u havent fixed by now... what it my be is ur baterry is dead or ur alternator is messed up same thing happened to me but my tach and speed ometer went crazy before it did all of this
[713]
May 14, 2012 03:23 PM
jay24k
Nov 15, 2008 02:58 PM
