gt42n.ball bearing
Old Aug 5, 2007 | 06:19 AM
ek9t72's Avatar
Default gt42n.ball bearing
I make one off the bigger mistake got a turbonetics t76bb and 1st run down the track is leaking oil out the compresor housing now here is my question I got a good deal in a gt42 j.bearing. what is the spool difference between this turbo and the 42r. I got a top mount with divide collector should I just get it
Modified by ek9t72 at 3:29 PM 8/5/2007
Old Aug 5, 2007 | 07:18 AM
SpeedDreamz.com's Avatar
Default Re: gt42n.ball bearing (ek9t72)
have you ever tried using complete words and periods? That may fly in other forums but not here.
Which 42r is it? And I am assuming that a j.bearing is a journal bearing?
Old Aug 5, 2007 | 07:33 AM
SPOOLINmatt's Avatar
Default Re: gt42n.ball bearing (SpeedDreamz.com)
im lost too. rephrase please.
Old Aug 5, 2007 | 07:39 AM
Axle's Avatar
Default Re: gt42n.ball bearing (SPOOLINmatt)
I've never seen a Laguna Seca Civic before, got pics?
Old Aug 5, 2007 | 08:04 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t72 &raquo;</TD></TR><TR><TD CLASS="quote">I make one off the bigger mistake got a turbonetics t76bb and 1st run down the track is leaking oil out the compresor housing now here is my question I got a good deal in a gt42 j.bearing what is the spool difference between this turbo and the 42r I got a top mount with divide collector should I just get it </TD></TR></TABLE>
Cortney Green aka uglyasscivic posted a dyno chart between a journal bearing GT4294 and a BB GT4294R , they made the same PEAK HP at max rpm from what I saw BUT looked to be 50+whp less from say 6000-9500 and spool looked pretty slow IMO . Maybe I can find that old chart again , I will look
I don't know if he ever ran that turbo at the track or not
Old Aug 5, 2007 | 09:55 AM
Default Re: gt42n.ball bearing (Axle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Axle &raquo;</TD></TR><TR><TD CLASS="quote">I've never seen a Laguna Seca Civic before, got pics? </TD></TR></TABLE>
PMs are your friend.
Old Aug 6, 2007 | 07:58 AM
Danny_EJ's Avatar
why does it matter on the spool? You take off in boost, and stay in boost each gear in drag racing. If it was a street car I could see the concern.
Old Aug 6, 2007 | 10:16 AM
Boner_Ben's Avatar
Default Re: (Danny_EJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danny_EJ &raquo;</TD></TR><TR><TD CLASS="quote">why does it matter on the spool? You take off in boost, and stay in boost each gear in drag racing. If it was a street car I could see the concern.</TD></TR></TABLE>
Transient response is the problem. If you have a turbo that wont stay in boost between shifts then it will not make it down the track so hot.
Old Aug 6, 2007 | 10:28 AM
GT40eg's Avatar
Default Re: (Boner_Ben)
i have a 4294 thats going on my car. it should be done in a couple weeks. ill let you know some info when its done.
Old Aug 7, 2007 | 12:24 PM
uglyasscivic's Avatar
Default Re: (GT40eg)
The journal bearing 4294 with a 1.15 rear housing and a full race divided manifold spools quicker than a Ball bearing T4/67 .81 rear housing. This test was done on a 2 liter b series. Peak power gains were about 110hp on that same test.
The Journal bearing 4294 was about 400rpm to the right of the BB 4294 but made the same peak power.
Old Aug 7, 2007 | 12:32 PM
BLK JDM's Avatar
Default Re: (uglyasscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscivic &raquo;</TD></TR><TR><TD CLASS="quote">The journal bearing 4294 with a 1.15 rear housing and a full race divided manifold spools quicker than a Ball bearing T4/67 .81 rear housing. This test was done on a 2 liter b series. Peak power gains were about 110hp on that same test.
The Journal bearing 4294 was about 400rpm to the right of the BB 4294 but made the same peak power.</TD></TR></TABLE>
Have you actually tested the journal bearing GT42 at the track?? How did it react? Did it fall out of boost? Some people would take that lagier spool if the transient responce isn't that bad. If it spools quicker than a T4/T67 then it seems like it wouldn't be that bad of a turbo to run on a SFWD car.
Old Aug 7, 2007 | 06:33 PM
ek9t72's Avatar
The Journal bearing 4294 was about 400rpm to the right of the BB 4294 but made the same peak power.</TD></TR></TABLE>thank you man this is all I needed to know to a the st##ped funny guys in here
Old Aug 9, 2007 | 07:38 PM
extremevtecracing's Avatar
Default Re: (ek9t72)
did your feelings get hurt there buddy. you need a hug. Bless your heart. We're with you!
balbowskie
Jun 17, 2015 04:15 PM
OmarR
Suspension & Brakes
Aug 8, 2013 09:44 PM
static-x
Jul 21, 2007 07:35 AM
ridnmyhonda
Mar 8, 2004 10:29 PM
Ryan C
Feb 6, 2004 02:50 PM
