shock help
Old Aug 4, 2007 | 09:59 PM
92civicx's Avatar
Default shock help
aright guys i've searched all over the ****** place and i couldn't find an answer.
as i was changing my wheel bearing i messed up the thread on the ball joint (upper control arm, drivers side). So on my way replacing uca i took out the bolts in the engine compartment, (not the middle one) and then the flange bolt on lower arm. i got room to take out the uca but now i can't get the flange bolt back on.
now i can't get the shock up to align with the lower arm to put in the flange bolt. it gets stuck and can't get the shock higher. I don't know if i fucked something up or what? its aligned vertically not horizontally.
i tried a jack. banging on it as it gets stuck trying to put it up holding the hub down. What should i do? have i messed anything up ?
Modified by 92civicx at 11:15 PM 8/4/2007
Modified by 92civicx at 11:47 AM 8/5/2007
Old Aug 5, 2007 | 11:03 AM
92civicx's Avatar
Default Re: shock help (92civicx)
here's a pic. can't bring that up!!
Old Aug 5, 2007 | 02:16 PM
EARLdaSQUIRREL's Avatar
official honda whore
if its bolted to the shock tower all you have to have someone do is stand on your hub assembly and push the shock fork into place and bolt it up
Old Aug 5, 2007 | 02:45 PM
92civicx's Avatar
Default Re: shock help (coptzer)
cool thnx man i just hate to expletive another thing up after messin up a few times.
Old Aug 5, 2007 | 04:55 PM
VTEC_PRODUCTION's Avatar
its hard to mess up STEEL!
Old Aug 5, 2007 | 08:33 PM
92civicx's Avatar
Default Re: shock help (VTEC_PRODUCTION)
ha ya it is. its those other things u to worry about....
myownreality
Feb 9, 2013 10:43 PM
LutherX
Aug 21, 2011 07:59 AM
speed_racer012
32
Mar 12, 2004 02:58 PM
IggDawg
Nov 20, 2003 06:25 PM
auto-x
Apr 15, 2003 12:46 AM
