Running 5 wire o2 on z6 p28
Ok. I got my d16z6 swap into my vx I kept my vx harness and the 5 wire o2 sensor. I ran my p07 ecu on the z6 for a while, then I got an auto p28. I've been running my vx 5 wire o2 sensor on my z6 with the p28 for a while and seems to be running ok. Will running the 5 wire only give me a CEL because I really don't care, or is it bad, should I rewire for a 4 wire?
anytime the chk engine light is on the vehicle wil run on last known good parameters so you probally arent getting as good as mpg or hp go back to a 4 wire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 »</TD></TR><TR><TD CLASS="quote">to be honest with you i have never seen a 5 wire but i do know what happens when the mil is on</TD></TR></TABLE>
mil??
mil??
the five wire O2 is actually a wideband, it will set CEL#1 in the P28.
unless your running an auto swap you need to pull open the ECU and remove RP17 and RP18, then solder a jumper across RP17 to get rid of CEL#19.
Any CEL is bad, it will drop your MPG and makes the car slower.
rewiring for a four wire O2 is really easy with the VX harness, if you've all ready adapted the O2 wires to accept the 4-wire O2 that is.
one wire to switch at the ECU and it will work fine. If you'd like to go down this path let me kow, I can tell you which wire to move.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">the five wire O2 is actually a wideband, it will set CEL#1 in the P28.
one wire to switch at the ECU and it will work fine. If you'd like to go down this path let me kow, I can tell you which wire to move.</TD></TR></TABLE>
I have a 5 speed swap, so thanks FYI on the auto to manual conversion.
So I have the 4 wire o2 sensor itself and I have not adapted it to fit to my harness (I still have the 5 wire left on there and the harness is unmodified). I don't have the inlet for the 4 wire o2 sensor to plug into (the one on the harness) but I can get it from my friends z6 harness I got the auto p28 from, or can I just wire it onto the 5 wire inlet/outlet plug thing?
So what exactly will I have to do to get this 4 wire o2 on there and not throwing any CEL's?
pinecone
Apr 1, 2006 05:51 PM
Built B16A
Oct 18, 2004 03:10 AM
trooper0641
34
Apr 23, 2004 12:29 PM
