Need help: car wont start without pressing gas pedal..
Old Aug 4, 2007 | 05:10 PM
2civic3's Avatar
Default Need help: car wont start without pressing gas pedal..
I got this rebuild engine(Z6) installed with t3 turbo, 450's, 255walboro and p28 chipped with crome. When I tried to start it, it cranks and i had to press/pump the gas pedal to get the engine running then after that i had to keep pressing/pumping the gas pedal to keep the engine running. When I let go the gas pedal the engine dies right away. What you guys think the problem here??
Thanks in advance!!
Old Aug 4, 2007 | 05:13 PM
Jared's Avatar
needs tuned
Old Aug 4, 2007 | 05:22 PM
2civic3's Avatar
The guy who chipped my ecu made a basemap for my setup then he'll street tune it for me when I get the car running. He changed the injectors to 450cc and my timing to 1 degree per boost.
Old Aug 4, 2007 | 05:28 PM
NJIN BUILDR's Avatar
Default Re: (2civic3)
Make sure you really have the tps connector hooked up to the tps.There is another connector in the harness that will fit the tps.I've done this before with the results your describing.
Old Aug 4, 2007 | 06:00 PM
2civic3's Avatar
where is tps located exactly???
Old Aug 4, 2007 | 06:07 PM
The end of the throttle plate shaft on the throttle body. The TPS (throttle position sensor).Check the wire colors on the connector and make sure they are the tps wiring.I think the other (wrong) connector is an egr or water temp sensor.
benji7288
Honda Civic (2001 - 2005)
May 22, 2009 11:04 AM
jjr_99prelude
Sep 26, 2007 04:40 PM
99delsol
Nov 28, 2006 08:09 PM
IsweatHONDA
Jul 14, 2006 12:06 PM
97itr86
Mar 15, 2003 05:31 AM
