Brake problems: deciphering between sitcking caliper pin or piston, or brake lines
Old Aug 4, 2007 | 12:16 PM
vinuneuro's Avatar
Default Brake problems: deciphering between sitcking caliper pin or piston, or brake lines
I just replaced the front pads, and when i took them out I noticed that the pass. pads had worn significantly more than the driver side. The odd thing is that I didn't really have any problems with the pins or the piston. If the piston is seized, it wouldn't go back into the cylinder right? And if the pins were seized they wouldn't slide back and forth. If the area that the pads 'float' on is rusted, would that cause this problem?
I'd like to resolve the problem before bedding the pads. Any advice would be appreciated.
szczerbanator
May 26, 2009 05:06 PM
Token Blk Guy
Nov 8, 2005 02:23 PM
Rampaging Llama
Nov 5, 2005 12:54 PM
