How do you connect AEM wideband UEGO Controller?
Old Aug 4, 2007 | 08:24 AM
92redhatch's Avatar
Default How do you connect AEM wideband UEGO Controller Guage type?
I have a 84mm ls vtec setup, with a 62-1 and im trying to connect my wideband so i can start the tuning process.
The are four different wires that i need to wire up. RED, BLACK, BLUE, WHITE.
So i know that RED goes to the battery ( positive).
I also know that black is ground.
Now my question is where do i wire up the BLUE and WHITE to?
thanks
mike
Modified by 92redhatch at 10:59 AM 8/4/2007
Old Aug 4, 2007 | 08:26 AM
mtber's Avatar
Default Re: How do you connect AEM wideband UEGO Controller? (92redhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a 84mm ls vtec setup, with a 62-1 and im trying to connect my wideband so i can start the tuning process.
thanks
mike</TD></TR></TABLE>
Mike,
Wire the ground directly to the battery.
Concerning the 12v make sure to get it off a clean source.
Concerning the blue wire, you probably wont use it.
Concerning the white wire, just run it to your ecu and leave it there for your tuner to wire it into which ever input he wants to use for logging etc..
Old Aug 4, 2007 | 08:27 AM
Turbo-charged's Avatar
are you logging your AFR through your EMS? if not, then you wont use either of those 2 wires.
Old Aug 4, 2007 | 09:03 AM
92redhatch's Avatar
Thanks guys. i was told to do exactly what you said.
And just to know what is the purpose of the BLUE wire?
And what is the purpose of the WHITE wire?
thanks
Old Aug 4, 2007 | 09:06 AM
92redhatch's Avatar
i was thinking about running the RED wire to the power source of my radio. Should i do that or should i run it directly to the battery?
thanks
Old Aug 4, 2007 | 09:11 AM
PrecisionH23a's Avatar
Default Re: (92redhatch)
Run the red to a 12v switched power source. If you do not have the uego ecu then you'll tie in your aem input wire to d14 on any obd1 ecu.
Old Aug 4, 2007 | 09:14 AM
OLD_HATCH's Avatar
power switched source only
beware if you are using the 30-2301 because some people have said either shortening or lengthenonn the actual wideband cables would cause inaccurate readings. (this applies to the o2 sensor cables only)
If you are using an AEM ems then after connected to the ecu disconect the sensor from the controller. at this point the wideband should be puting out a straight 4 volts (doube check that figure) then yu adjust the gain in the ems until it sees the 4 volts that the eugo controller is putting out.
92redhatch's Avatar
what switched power source do you recomend for the RED wire? Should i run the RED wire Directly the the positive on the battery?
i appreciate your help. i want this to be as clean and simple as possible.
Thanks
Modified by 92redhatch at 10:40 AM 8/4/2007
Old Aug 4, 2007 | 09:15 AM
92redhatch's Avatar
Im using an obd1 p28. ANd the AEM UEGO part number is 30-4100. Its the Guage type wideband.
the car is a 92 civic hatchback.
Modified by 92redhatch at 10:47 AM 8/4/2007
Old Aug 4, 2007 | 10:16 AM
92redhatch's Avatar
anyone?
Old Aug 4, 2007 | 05:56 PM
92redhatch's Avatar
BUMP!!!
Old Aug 5, 2007 | 07:15 AM
92redhatch's Avatar
So do i run the RED wire directly to the battery?
Old Aug 5, 2007 | 07:18 AM
NO! if you run the red wire to the battery the wideband will be on all the time, even when your not driving the car. you need to ground the black wire, the red wire needs to go to a power source that is only on when the key is on.
wire the white wire into the ecu if your management has the capability to dattalog AFR. if it doesnt, than your install is done.
Old Aug 5, 2007 | 11:17 AM
92redhatch's Avatar
Default Re: (Turbo-charged)
Thanks for your input
Now were do you recomend I wire the white wire 2?
Thanks
Old Aug 5, 2007 | 11:50 AM
Muckman's Avatar
Moderator in Chief
The white wire is the 5v signal output. It goes to the ecu, primary O2 sensor pin. It can be configured for wideband or narrow band calibration, depending on which ecu your using. The blue wire is for serial output to log the sensor with a 3rd party app to log the sensor.
Connect the red wire to the switched ignition power from the cabin fuse box.
Black is ground obviously.
Doesnt the manual explain all this?
Old Aug 5, 2007 | 12:22 PM
92redhatch's Avatar
yes the manual explains most of it. i just wanted to know where exactly most people wire the RED wire to.??
the manual says any 12v power with a 10amp fuse.
Old Aug 5, 2007 | 02:37 PM
92redhatch's Avatar
Old Aug 5, 2007 | 04:35 PM
damn man sounds like you should swing by your local shop and have them put it in for you. the red wire goes to any switch 12v source. there is probably 3035 differnt options on that.
Old Aug 5, 2007 | 08:47 PM
92redhatch's Avatar
ive done plenty of wiring. im just being lazy.
I dont feel like looking for my test light and saudering (spelling) iron.
THanks for the help anyways.
denshu
Lighting
Nov 8, 2007 08:02 AM
mckeehan
Honda Civic (2001 - 2005)
Nov 19, 2006 09:34 PM
Beau Gotti
Feb 6, 2006 02:53 PM
Jeager521
Audio / Security / Video
Oct 20, 2002 10:49 AM
