overspray removal?
Old Aug 4, 2007 | 03:26 AM
emooheo's Avatar
Default overspray removal?
yeah.. well i bought a car with a maaco paintjob so there is some overspray on the trim around the windows and stuff... what would be the best way to get rid of it without damaging the trim?
thanks
Old Aug 4, 2007 | 10:02 AM
JERRRK's Avatar
Default Re: overspray removal? (emooheo)
either carefully wipe with a bit of thinner and not wiping on the paint or mask off the trim/window mouldings and paint them a flat black/trim black with a spary can and spray light coats.
Old Aug 5, 2007 | 08:19 PM
TurbochargedInnovation's Avatar
Default Re: overspray removal? (JERRRK)
Clay bar everything except rubber moldings.. Reducer/laquer thinner or Acetone works well on removing overspray, just be carefull when using.
Old Aug 5, 2007 | 10:25 PM
S-=N=-A-=K=-E's Avatar
Wet sand the paint off with 2000 grit for the glass... Not sure about the trim though..
Old Aug 6, 2007 | 07:42 PM
vsmhatched's Avatar
Default Re: overspray removal? (S-=N=-A-=K=-E)
razor blade for glass...and claybar for the rest.. dont use thinner on painted peices..it'll strip or dull the paint
Old Aug 6, 2007 | 09:30 PM
Ohgodzirra's Avatar
Default Re: overspray removal? (GreyDel)
Acetone, not mineral spirits as far as paint thinner goes, it works wonders on the glass, Walmart brand carb clean works great as well. Molding can sometimes become damaged from the acetone and cleaners so be careful.
Old Aug 7, 2007 | 06:16 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S-=N=-A-=K=-E &raquo;</TD></TR><TR><TD CLASS="quote">Wet sand the paint off with 2000 grit for the glass... Not sure about the trim though..</TD></TR></TABLE>
Wet sand the glass? Easiest way is to use steel wool or a razor blade. Steel wool will get everything off the glass.
Old Aug 7, 2007 | 10:40 AM
shad0wslay3r's Avatar
Soap/water mix with steel wool
Old Aug 7, 2007 | 11:26 AM
Ohgodzirra's Avatar
Default Re: (shad0wslay3r)
Jesus, you just can use carb clean on a rag for the windows, it takes about 5 seconds and doesn't involve possibly scratching the surrounding moldings.
Old Aug 7, 2007 | 12:49 PM
WihaSi's Avatar
Default Re: (Ohgodzirra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ohgodzirra &raquo;</TD></TR><TR><TD CLASS="quote">Jesus, you just can use carb clean on a rag for the windows, it takes about 5 seconds and doesn't involve possibly scratching the surrounding moldings.</TD></TR></TABLE>
Steel wool isn't that abrasive, you can scratch moldings and such, but you'd really have to be pushing hard.
Old Aug 13, 2007 | 01:55 PM
emooheo's Avatar
i totally forgot i made this thread, no one really explained how to get it off the trim.. any tips would be appreciated
Old Aug 14, 2007 | 08:24 AM
milkmanLCA's Avatar
Default Re: (emooheo)
razor blade/ steel wool for the windows, the wool works great. and thinner on paint, it wont expletive it up, just apply the thinner to a cloth and do not let it sit, have done it too many times, works great
Old May 25, 2008 | 04:43 PM
KansasKev's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emooheo &raquo;</TD></TR><TR><TD CLASS="quote">i totally forgot i made this thread, no one really explained how to get it off the trim.. any tips would be appreciated</TD></TR></TABLE>
I am looking for the same thing. I don't want to repaint the trim!
Old May 25, 2008 | 04:54 PM
gstewart27's Avatar
I wet sanded my trim with a very high grade sandpaper, think it was 3000 grit, and then used tyre shine on it - worked a treat!
Be careful not to make any deep scratches in the trim though
cdplayerto
Honda CR-V & Element
11
Oct 13, 2016 06:24 PM
EK_B
Paint and Body
Apr 23, 2008 02:21 PM
blackriceman
Aug 16, 2004 01:57 PM
civictypenos
Nov 17, 2003 06:48 AM
