Werid idle problem with y8 any help?
Old Aug 4, 2007 | 12:47 AM
2slow4stock's Avatar
Default Werid idle problem with y8 any help?
Ok, I've had this swap in for about 2 months... I switched from a chipped ecu (p28) to a virgin p28 and now the idle is all shitty. It's basicly surging. No kinks in the coolant lines. Coolant is full. IACV is working, and no vacume leak.
When I disconnect the IACV it idles nice. But when I plug it back in it surges again. Then I switched back to the chipped ecu it idles perfect, so i'm stumped. So chipped ecu no surgin idles perfect and virgin ecu surges. Motor is a d16y8.
So if anyone has any input please give it out. Letting my friend use the chipped ecu. I've searched in for "d16y8" nothing helpful. Thanks in advanced
Old Aug 4, 2007 | 07:16 AM
jlicrx's Avatar
Default Re: Werid idle problem with y8 any help? (2slow4stock)
you have already found the problem - IACV - if you have fluctuating idle, the book says you unplug the IACV and idle should drop to around 500-600 rpm and remain steady - if it does, the IACV is not working correctly - if it still fluctuates, look for vacuum leak, bad MAP or air in the cooling system
Old Aug 4, 2007 | 04:34 PM
No, it didn't stay steady. around 500-600 it was still 1000-1200. No vacuum leak, checked all over. It's hard to explain but with the chipped ecu it stays steady...
schwing27
21
Mar 17, 2009 08:49 AM
turbojdmhatch
Apr 17, 2008 10:45 AM
mikeunreal2
31
Mar 12, 2006 10:28 PM
b_serious
Dec 1, 2005 08:21 PM
BeerBaron105
Jun 7, 2005 02:22 AM
