Rebuilding block or buy a new one?
Old Aug 3, 2007 | 07:14 PM
B00stedEh3's Avatar
Default Rebuilding block or buy a new one?
What will be cheaper...........rebuilding my block or just replacing it with a lower milage one?
This is for my daily, so nothing afermarket or stuff like that.
I've just reached that point where I need a fresh running motor again.
Thanks for the advice.
Old Aug 3, 2007 | 10:22 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: Rebuilding block or buy a new one? (B00stedEh3)
I would personally rebuild...
Start out FRESH...
Old Aug 3, 2007 | 10:23 PM
Byaaah!'s Avatar
Default Re: Rebuilding block or buy a new one? (Project95LS-VTEC)
That sounded weird, let me rephrase that, "Personally I would rebuild"...
Old Aug 3, 2007 | 10:31 PM
ishbog's Avatar
depends what you're doing to it. if you just want the reliability of a low mileage engine, then rebuild the internals -- piston rings etc. theres no point in getting another block. if you want to boost or something, bore it or sleeve it, then its still using your current block...
Old Aug 3, 2007 | 10:34 PM
Byaaah!'s Avatar
Default Re: (ishbog)
I think he just wants a plain 100% stock motor...
Replace pistons, rods, rings, all internals...
Old Aug 3, 2007 | 10:43 PM
JThrasher79's Avatar
Default Re: (Project95LS-VTEC)
he just needs a hone and ring job, and replace the bearings..
Old Aug 5, 2007 | 06:17 PM
B00stedEh3's Avatar
Default Re: (JThrasher79)
yes i just need a 100% reliable daily driver. The clock reads 140k right now, and block is leaking Oil, nothing major just a tad.
any idea on how much it would run me with parts?
Old Aug 5, 2007 | 06:34 PM
Byaaah!'s Avatar
Default Re: (B00stedEh3)
So your trying to rebuild EVERYTHING???
Old Aug 5, 2007 | 06:52 PM
nokturnal_munkeeboy's Avatar
rebuild it
Old Aug 5, 2007 | 08:04 PM
B00stedEh3's Avatar
Default Re: Rebuilding block or buy a new one? (nokturnal_munkeeboy)
yes long/short block.
crxcess
Sep 7, 2008 04:32 PM
GSROWNSU
Apr 15, 2007 11:36 AM
preludesi93-arg
Jun 23, 2005 10:46 AM
likaciv
May 15, 2003 09:13 PM
jg
Mar 7, 2003 12:19 PM
