H22 swap using a H23 wiring??
I just got a h22 motor and trans that i am putting in my 92 prelude that had a H23. The wiring that came on the H22 what cut up bad so i was going to use the wiring off the H23 but there are 3 sensors that there are no plugs one is the v-Tec One has something to do with the fuel psi and the other is a map sensor i think. Does anyone know how i need to wire this or do i even need them?? HJeres a pic
that is what i was thinking. Any info on the map sensor.. One other question the H23 has a external coil and the H22 has a internal coil every thing pluged up i just have the extra coil plug that has no where to go.
Modified by quickv8s10 at 8:08 PM 8/3/2007
I am running a jdm h22a with the usdm p13 i used the map sensor on the firewall, I have ha no problems, but since you are using a jdm p13 I’m not sure what you should do. I would leave the map sensor on the fire wall and see if it throws any codes.
And you can use the internal coil dizzy that came with the swap; you just need to jump the external coil plug with a 20 amp fuse. There are three wires on it, jump the two that are right next to each other. Not the blue wire. You can also cut them and put the together, but i like just taping the fuse in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc »</TD></TR><TR><TD CLASS="quote">
And you can use the internal coil dizzy that came with the swap; you just need to jump the external coil plug with a 20 amp fuse. There are three wires on it, jump the two that are right next to each other. Not the blue wire. You can also cut them and put the together, but i like just taping the fuse in there</TD></TR></TABLE>
Yeah when I did my swap, I found that the H23 TB was actually a lil bit larger, so I used it for that reason as well, and I used the external coil dist from the H23 as well, and I like that I can easily use a different coil for the setup if I want too.
sscivicsi
Jun 15, 2008 10:05 AM
