clutch pedel....
i did my clutch and i just finished with everything, and i just noticed that my clutch pedel was all the way to the floor and it just moves up and down very easily i dont know when this happened for the first time but can someone tell me why? hopefully its something easy to fix..maybe...
1. Unscrew nipple so fluid comes out. ( Master Cylinder in front of header.
2. Have a friend pump the clutch pedal while continuing to keep the resevoir full
3. Do this until all bubbles are out
clutch will go back to normal. keep in mind pumping needs to be done by hand first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRDC2 »</TD></TR><TR><TD CLASS="quote">1. Unscrew nipple so fluid comes out. ( Master Cylinder in front of header.
clutch will go back to normal. keep in mind pumping needs to be done by hand first</TD></TR></TABLE>
its a slave cylinder fron of the header.
check the master cylinder 1st.
