b16 crx, vtec trouble
Old Jun 11, 2002 | 10:52 AM
r7's Avatar
r7
Default b16 crx, vtec trouble
ok, i am not getting any ecu codes, so does that mean the wiring is correct ?
vtec is not working.. anything thoughts ?
Old Jun 11, 2002 | 10:59 AM
pg_thao's Avatar
Default Re: b16 crx, vtec trouble (r7)
check the ground wires and check the solenoid, checking the oil will be good thing to do also..
Old Jun 11, 2002 | 11:19 AM
r7's Avatar
r7
Default Re: b16 crx, vtec trouble (pg_thao)
grounds are good, oil level good
Old Jun 11, 2002 | 11:33 AM
EL Vap133's Avatar
Is your speedo working? Also, let the engine get warm before you drive it so that VTEC will kick in.
Old Jun 11, 2002 | 11:41 AM
r7's Avatar
r7
Default Re: b16 crx, vtec trouble (Vap133)
speedo is working, car warm, still not kick in .. ?
Old Jun 12, 2002 | 03:33 PM
r7's Avatar
r7
anyone ?
Old Jun 12, 2002 | 04:24 PM
rice_classic's Avatar
bad knock sensor,
vtec solenoid,
or operator error?
last ones a small joke!
Old Jun 12, 2002 | 07:29 PM
r7's Avatar
r7
Default Re: b16 crx, vtec trouble (rice_classic)
would i get an ecu code if i had bad knock sensor, or vtec solenoid ?
Old Jun 13, 2002 | 07:00 AM
Blown90hatcH's Avatar
You would get a code if you have a knock sensor or vtec solenoid malfunction. Have you checked the pressure at the front of the head around the Vtec rpm engagement?
Old Jun 13, 2002 | 07:33 AM
SuperCivic's Avatar
which ecu?
Old Jun 13, 2002 | 08:38 AM
CHEETAH's Avatar
just test the solenoid with +12v from battery, it should click .. after that check the connectivity from ecu to solenoid, which ecu ? PR3 or PWO I'm assuming ...
Greg
Old Jun 13, 2002 | 09:09 AM
ProstockH22crx's Avatar
Make sure you have a manual ECU.
Old Jun 13, 2002 | 10:21 AM
r7's Avatar
r7
Default Re: b16 crx, vtec trouble (ProstockH22crx)
pr3, i will try to engage the solenoid.. .
ntoxicatedtigah
Jun 24, 2009 02:56 PM
3.504
Oct 4, 2005 11:26 AM
spoon23_JDizM AkA SpOoN20
Sep 14, 2005 10:09 AM
pr3crx
Feb 5, 2004 10:04 AM
vtecdhatch93
Sep 21, 2002 05:14 PM
