p30 ecu error codes - VTEC soleniod and ECT (6 and 21)
Im getting error code 6 which is vtec soleniod but I know the soleniod is good because I hardwired it to the battery and it engaged... what could cause that? I also re-ran the 2 wires (vtec pressure switch and vtec soleniod) from the ecu to the 2 sensors. So what the f*** can it be?
The other error code is 21 which is ECT(Engine Coolant Temp) that the same thing as the coolant temp sensor which is on the left/front side of the head correct? The only thing is, is that those 2 sensors are directlty next to each other but, another thing being that i have a cx with b16 and I used my stock d15 wiring harnes and just tapped into the things that needed to be like - knock sens. all vtec wires and o2 sensor
If anyone knows the pinouts where VTEC soleniod and ECT wires go to PLEASE let me know sucks having a HB Hybrid when installing freshly surfaced head with ITR cams/springs/retainers, Port & Polished, and 5 angle valve job nd not being to even feel the difference cuz i cant go into vtec and that ECT sensor makes it run like ****.....PLEASE FRIENDS HELP A BROTHA' OUT w/ details Mark-CT
flat-blk-HB
16
09-30-2002 07:04 PM
