gsr or ls axle????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network »</TD></TR><TR><TD CLASS="quote">any b series axle</TD></TR></TABLE>
incorrect.
Any 32mm b-series Hydro axles will work.
The exception is the 36mm ITR axle.
incorrect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
incorrect.
good point i forgot about that lol.
incorrect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuisek9 »</TD></TR><TR><TD CLASS="quote">ok i got a 96 civic a i got a gsr engine so which axle is the 1 that am suppost to put in there??oh is the driver side!!</TD></TR></TABLE>
For the left axle, you can use any of the following:
- '94-01 Integra USDM (trim level and transmission doesn't matter)
- '94-97 del Sol VTEC
- '99-00 Civic Si
You cannot use a '90-93 Integra left axle because their intermediate shaft is female. You cannot use a JDM ITR axle because they have the larger outer CV that takes a 36mm nut.
- '99-00 Civic Si
Maybe you keep breaking axles because your driving is as bad as your grammar.
if you are using a 90-93 integra intermediate shaft then you need a 90-93 integra (non-ABS) driver side axle.
just for the record, they made integras in 1994+ without ABS, no need to use 90-93 axles because of this.
