Brake spec info re: 96-00 Civics
Old Aug 2, 2007 | 05:54 PM
anjapower's Avatar
Default Brake spec info re: 96-00 Civics
Are the brakes the same across all the Civics from 96-00 save for the Si?
TIA
Old Aug 2, 2007 | 05:59 PM
sk8shorty012's Avatar
No, the dx / lx had smaller 9.5" front brake rotors and smaller calipers / pads.
The ex / si had 10.3" front rotors with larger calipers / pads.
The dx / lx / ex had rear drums.
The si had rear disc brakes.
Old Aug 2, 2007 | 06:10 PM
anjapower's Avatar
Default Re: (sk8shorty012)
awesome, thanks for clearing that up. I'm guessing it's a simple caliper swap and disc swap that needs to be done to the dx/lx to get it up to "EX spec"?
Old Aug 2, 2007 | 06:24 PM
NOFX's Avatar
H-T White Ops
That info is here too (and for all the trims, not just DX, EX, LX and Si):
https://honda-tech.com/zerothread/2055230
Old Aug 2, 2007 | 06:25 PM
no. You need to get the EX / Si front knuckles if you want to upgrade. The reason being is, the caliper mounting bracket sits out further on the ex / si knuckles (b/c of the larger diameter rotor).
Old Aug 3, 2007 | 07:34 AM
anjapower's Avatar
Thanks very much
Arthas
Mar 15, 2011 01:18 PM
invisible
29
May 3, 2007 08:13 AM
Fatty_1775
Jun 6, 2006 12:32 PM
.dave
Nov 25, 2003 06:34 AM
ninji
Nov 11, 2002 01:10 PM
