1995 Honda Civic LX, Which wire is for the radio memory?
Everything is wired perfectly except that the stereo, doesn't hold the preset station memory. Does anyone know which wire I am suppose to splice and connect to the antenna memory wire coming out of the headunit wire harness?
White with yellow (or blue) stripe (looks like you have a blue stripe) should be connected to the yellow wire from the headunit.
Ant/rem means antenna/remote, which is used for power antennas and turning on amplifiers. What color is your "antenna memory wire"?
http://installdr.com/Harnesses/HA-Wiring.pdf
Puedes decirme q colores van con una conection al estereo. La razon es me abrieron el carro y cortaron los vcables y queria ponerlo sin la extencion regular.
6KAOS6
26
Feb 19, 2011 07:22 PM
br3kk3
Honda Civic (2001 - 2005)
Dec 30, 2009 09:53 AM
xunkn0vvnx
Aug 2, 2007 07:45 PM
