distrib cap question
Old Aug 2, 2007 | 03:25 PM
tmrtwo's Avatar
Default distrib cap question
where does the wire go to thats on the bottom of the distributor cap go.....the plug wires i got in but cant find where the bottom wire goes. I have a helms and chilton and it doesnt show in there.
Old Aug 2, 2007 | 03:28 PM
MLBZ521's Avatar
Default Re: distrib cap question (tmrtwo)
How many "Wires" do you have? And what kind of Dizzy do you have?? A Internal or External Coil?
Old Aug 2, 2007 | 03:32 PM
tmrtwo's Avatar
Default Re: distrib cap question (MLBZ521)
theres 5 wires...its a h22 i believe internal coil maybe how can i tell? it has a rotor inside if that helps..... looks like this
0 0
0 0
o <---thats the one i need to know where it goes
Old Aug 2, 2007 | 03:51 PM
mattsnooz's Avatar
the bottom one sounds like the ground wire that goes to the top of your igniter
The plug on the other end of the dizzy wires is a shorter but wider one correct??
(opposite end to one that goes on dizzy so you know.)
Giant_Bean's Avatar
how many wires did your old cap have? if it had 4 it is internal coil, if it had 5, it is external coil, and the 5th wire would go to the coil
Old Aug 4, 2007 | 06:15 PM
tmrtwo's Avatar
Default Re: distrib cap question (Giant_Bean)
ok that sounds right but will this distributor cap still work if it has a outlet for the coil....?
Old Aug 4, 2007 | 08:12 PM
saikou's Avatar
It will not work unless you have the ignition coil plugged in.
If you have a USDM H22, you will have an external coil distributor.
Old Aug 5, 2007 | 11:52 AM
tmrtwo's Avatar
Default Re: (saikou)
that explains my h23vtec build not getting spark. Not sure if its usdm or jdm. If it has a rotor inside the distributor its a internal coil right?
Old Aug 5, 2007 | 11:57 AM
saikou's Avatar
Default Re: (tmrtwo)
All distributors utilize a rotor, man. If you're trying to start your car without the ignition coil wire plugged into the cap, it is definitely not going to start.
Old Aug 6, 2007 | 03:37 AM
tmrtwo's Avatar
theres nowhere for me to plug in the ignition coil into....it must be a jdm then....distributor cam of a h23 so whatever ill try and figure it out. I bought the distrib cap from autozone....they must have gave me the wrong one. Dman that caused alot of confusion for me..lol
Old Aug 6, 2007 | 04:27 AM
Maharajamd's Avatar
JDM = internal = 4 wires
USDM = external = 5 wires
If you can grasp the hybrid 22/23 engine, you should be able to hand this...
Old Aug 9, 2007 | 02:04 PM
tmrtwo's Avatar
Default Re: (Maharajamd)
i got it taken car of....im a retard and the coil was still mounted up to the h23 head. Im almost done wit my build ...only prob i didnt replace a o ring on the waterpipe and it leaks ...should be in on monday tho from honda and start that beast up
MalcolmV8
May 13, 2012 08:35 AM
jspeedy
Jun 26, 2010 05:04 AM
averyvm
May 8, 2009 11:37 PM
hondatuningboi96
Jun 19, 2007 10:36 PM
89_ZC_crx
Aug 10, 2005 11:11 PM
