brake
Old Aug 2, 2007 | 12:23 PM
16v's Avatar
16v
Default brake
my D15B7 civic have bad brakes, i want to change front brake disks and set from other car could you tell me which car's brake disk will fit on my civic? i have only 14" rims and which maximum rotor size will fit on 14"rims? if i change only brake disks an set bigger than stock wiil my brake improve?
Old Aug 2, 2007 | 12:25 PM
Syndacate's Avatar
Default Re: brake (16v)
Any '92-'00 Civic or '94-'01 Integra front disks should work.
As for if JUST bigger rotors will help? No, if the caliper isn't pressing a larger pad, it won't help any.
Old Aug 2, 2007 | 01:00 PM
MJ0LNIR's Avatar
Is there any reason that you're using rotors from another car? Generally, I have always used the rule that change the discs, change the pads, and use NEW parts. Generic pads and rotors are not very expensive either.
Old Aug 2, 2007 | 01:08 PM
commguy's Avatar
Default Re: brake (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">As for if JUST bigger rotors will help? No, if the caliper isn't pressing a larger pad, it won't help any.</TD></TR></TABLE>
I know I'm a total noob here but, wouldn't a bigger brake help simply for leverage? See where I'm coming from? Like, your calipers don't have to work as hard to do the same job? It's not all about pad/rotor contact area. I'm totally not attacking you here, I've read some of your posts, I believe you know what you're talking about, ya know, so correct me if I'm wrong...
sloassSi
18
Jun 20, 2010 02:01 AM
Fatcobra
Mar 27, 2007 11:45 AM
b16a2EBP
Mar 3, 2006 07:09 PM
YipMan_Style
Oct 29, 2002 08:55 AM
xpsonic
May 17, 2002 01:50 PM
