so is seafoam good or bad?
Old Aug 2, 2007 | 09:35 AM
darkwater_ghost's Avatar
Default so is seafoam good or bad?
so I was just woundering if seafoam is good for you car or bad, never used it myself and I hear the ratings are about 50/50. but I'm thinking you car should probably be in pretty bad shape if you want to try it.
Old Aug 2, 2007 | 09:42 AM
philosofy1's Avatar
Default Re: so is seafoam good or bad? (darkwater_ghost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkwater_ghost &raquo;</TD></TR><TR><TD CLASS="quote">so I was just woundering if seafoam is good for you car or bad, never used it myself and I hear the ratings are about 50/50. but I'm thinking you car should probably be in pretty bad shape if you want to try it.</TD></TR></TABLE>
i don't recommend it. it's not worth taking the chance or risking my motor.
here are a couple of reasons why:
https://honda-tech.com/zerothread?id=2047713
https://honda-tech.com/zerothread?id=2057118
https://honda-tech.com/zerothread?id=1927165
and there is alot more, if you do search you will find them.
Old Aug 2, 2007 | 09:43 AM
95ProjectEJ1's Avatar
how many miles are on your motor? Have you performed the normal maintainence every 3-6k miles (tune up, oil change etc)?
It you slowly introduce Seafoam into your motor via the brake booster vacuum line you will be fine. Use the proper amount and go slowly. You can put it in the gas tank also ... just steer away from the crankcase. Remember, if your motor is held up by carbon deposits and sludge then you will notice leaks after Seafoam is used.
nub_pwn
47
Dec 7, 2006 08:58 PM
viper104
Honda Motorcycles
16
Aug 26, 2006 12:44 PM
vsual
28
Dec 6, 2001 07:02 AM
