Aluminum sheet metal for intake plenum. What kind?
Old Aug 1, 2007 | 09:45 PM
Westrock2000's Avatar
Default Aluminum sheet metal for intake plenum. What kind?
For a plenum design I want to have an underlying skeleton that I can attach the runners and the endcaps/flanges to, and then wrap an aluminum skin over it.
Like so
The skeleton will be 6061 1/4" aluminum. What thickness aluminum sheet metal can I use that will bend over easily, but still be weldable. I'm guessing that keeping it 6061 would be the best bet?
Heres some of the thickness mcmaster-car offers
.032" | .033" | .04" | .048" | .05" | .055" | .06" | .062" | 1/16"
Modified by Westrock2000 at 12:57 AM 8/2/2007
Old Aug 2, 2007 | 03:04 AM
tepid1's Avatar
Default Re: Aluminum sheet metal for intake plenum. What kind? (Westrock2000)
You can still use 6061, but not T6. You will want something that has not been hardened so that you can form it without destroying the metal.
Old Aug 2, 2007 | 04:42 AM
tony1's Avatar
Default Re: Aluminum sheet metal for intake plenum. What kind? (tepid1)
I'd recommend 3003 or 5052 if you're going to bend it. Is this manifold going to be in a turbocharged application? You could probably get by with .065 in an n/a app, but definitely not in a turbo app.
Old Aug 2, 2007 | 05:51 AM
hootiehoo's Avatar
Default Re: Aluminum sheet metal for intake plenum. What kind? (tony1)
take a look at http://www.rossmachineracing.com
Old Aug 2, 2007 | 06:02 AM
all_motor_mike's Avatar
Default Re: Aluminum sheet metal for intake plenum. What kind? (hootiehoo)
dude just get a tube of what diameter u need (i use 1/8" wall 6061 for my stuff) and cut it in half............... thats waht i do for my manifolds.
Old Aug 2, 2007 | 06:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hootiehoo &raquo;</TD></TR><TR><TD CLASS="quote">take a look at http://www.rossmachineracing.com</TD></TR></TABLE>
I'm actually using their halfround for the skeleton. However the ID is too small to fit the velocity stacks comfortably (87mm bellmouth & 89mm ID halfround). But by wrapping a skin around, I gain an additional 1/2" which gives me breathing room around the stacks.
This particular one would be for NA, potential future customers may look into FI applications though.
Tony do you know any good welders in the DFW area?
Old Aug 2, 2007 | 08:27 AM
Bantam's Avatar
2nd Coolest Person in DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Tony do you know any good welders in the DFW area?</TD></TR></TABLE>
I'm guessing that he's going to reccomend himself
and I've also read that a TB in that location isnt the greatest for airflow distribution, which might make a pretty big difference in NA performance.
I think you'd want to move the TB up above the stacks more, and "away" from the rest of the manifold.
Old Aug 2, 2007 | 03:57 PM
Sims's Avatar
Default Re: Aluminum sheet metal for intake plenum. What kind? (tharptroy)
Tony is as good of a welder as you will find...
There aren't a ton of really good welders in this area, well at least not like Austin or Houston.
Old Aug 2, 2007 | 04:18 PM
tony1's Avatar
I can stick metal together ok on a good day
Old Aug 2, 2007 | 06:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I can stick metal together ok on a good day </TD></TR></TABLE>
OK, I wasn't sure or not. I had a close friend whom you tuned his AEM EMS, so I knew that aspect, but I wasn't sure about custom fab stuff.
Old Aug 2, 2007 | 07:50 PM
Bantam's Avatar
OK, I wasn't sure or not. I had a close friend whom you tuned his AEM EMS, so I knew that aspect, but I wasn't sure about custom fab stuff.</TD></TR></TABLE>
yeah, tony1 posts some pics of his work in this section, and its all top notch
whats your take on my design comment? not enough space, evidence to prove otherwise, or what?
MilwaukeeMotorwerks
Welding / Fabrication
Mar 22, 2009 03:23 PM
Justin Olson
24
Sep 17, 2008 09:49 PM
Fred Allen Burge
Feb 12, 2006 05:10 PM
Keyhole
Aug 4, 2005 05:27 PM
egg
Sep 20, 2003 05:22 AM
