how often do you change your gas lense?
Old Aug 1, 2007 | 11:07 AM
weiRtech's Avatar
OG Fabricator
Default how often do you change your gas lense?
just curious. mine is looking crusty so i think it is time to replace it.
Old Aug 1, 2007 | 11:33 AM
ebydrc's Avatar
Banned
i use them till i break em.
Old Aug 1, 2007 | 12:41 PM
ManBearPig4silly's Avatar
Depends on what I'm doing. I find they get eaten up more when I'm welding cast AL and **** pops into the lense and burns holes.
Old Aug 1, 2007 | 03:38 PM
RCautoworks's Avatar
Default Re: (ManBearPig4silly)
Usually never change them out unless I see one clogged, not to long ago I know a company online was selling a few gas lens that were bad... be careful.
Old Aug 1, 2007 | 04:48 PM
91jdmhatchback's Avatar
Default Re: (RCautoworks)
i welded on one for awhile then did some welding on cast al and it went to **** so now i check to see if it works every couple weeks
Old Aug 1, 2007 | 05:20 PM
DESTROYER's Avatar
if there is a couple pieces of spatter, i dont worry about it. I am not perfect though, and will occasionally stick my T and pop some crap into it. I just use discretion that's all.
Old Aug 1, 2007 | 06:28 PM
k24em2's Avatar
Default Re: (91jdmhatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">i welded on one for awhile then did some welding on cast al and it went to **** so now i check to see if it works every couple weeks</TD></TR></TABLE>
Cast AL is a bitch...I usually just throw on a normal cup and collet when I'm welding cast AL.
Old Aug 1, 2007 | 06:31 PM
Bailhatch's Avatar
Default Re: (k24em2)
I usually ditch the gas lens for aluminum and mild steel
Old Aug 1, 2007 | 06:41 PM
DESTROYER's Avatar
Default Re: (Bailhatch)
good call. not necessarily mild steel, but anything that isn't DOM or CR stuff.
...the trick is... do i HAVE any non-GL collets?
Old Aug 2, 2007 | 07:33 AM
brightside's Avatar
Default Re: (DESTROYER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DESTROYER &raquo;</TD></TR><TR><TD CLASS="quote">good call. not necessarily mild steel, but anything that isn't DOM or CR stuff.
...the trick is... do i HAVE any non-GL collets?</TD></TR></TABLE>
or better yet, non-GL cups?
Old Aug 2, 2007 | 08:30 AM
ebydrc's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">I usually ditch the gas lens for aluminum and mild steel</TD></TR></TABLE>
plus one
Old Aug 2, 2007 | 11:26 AM
Bailhatch's Avatar
right right, hot rolled suxorz!
Old Aug 3, 2007 | 06:24 AM
weiRtech's Avatar
OG Fabricator
thanks for the replies guys. i usually don't use the gas lense for heavy aluminum welding, but only because at high amps it pops the end of the illumina cup off.
Old Aug 3, 2007 | 02:41 PM
k24em2's Avatar
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies guys. i usually don't use the gas lense for heavy aluminum welding, but only because at high amps it pops the end of the illumina cup off.</TD></TR></TABLE>
Do you have the insulator between the cup and the torch? If you don't put that on it'll bust the end off of it.
Old Aug 3, 2007 | 02:57 PM
DESTROYER's Avatar
eh, it always did it for me at over 200A...
weird how it goes too, explodes in a blue fireball and whatever fragments hit the ground stains the concrete blue where it hits... explanation?
integra pride
May 26, 2006 10:36 AM
Skeletor_1320
Apr 28, 2006 04:59 PM
all_conference
67
Jul 28, 2005 02:05 PM
thatonejewishguy
May 28, 2005 08:41 PM
RCautoworks
Welding / Fabrication
Nov 9, 2004 06:17 AM
