what dose the iac valve look like on a 91 sedan?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LATINOSPEED »</TD></TR><TR><TD CLASS="quote">thanks do you know how to clean it?</TD></TR></TABLE>
Take it off and use carb cleaner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LATINOSPEED »</TD></TR><TR><TD CLASS="quote">thanks do you know how to clean it?</TD></TR></TABLE>disconnect the green connector - unbolt it from the manifold - turn it over and you will see 2 holes - spray carb cleaner down in the holes - let it set a while then empty carb cleaner - do this a few times until you get out all of the carbon build-up that you can - i have found that most of the time cleaning it doesn't help - do you have idle fluctuating up and down or just high? just high is probably not the EACV, but is more likely a vacuum leak somewhere
Honduh Chicken
Jul 1, 2006 08:53 PM
