spark plugs drenched in oil
Old Aug 1, 2007 | 07:38 AM
atarigamer01's Avatar
Default spark plugs drenched in oil
My car just shut off about a week ago while driving. No smoke or leaking that I noticed. I had it pressure tested and the mechanic said there was no pressure. So I had it towed home and I pulled the spark plug cables out and it was drenched in oil. Every cylinder was like that. I actually replaced the valve cover gasket and spark plug tube seals before my car broke down. So Im thinking its the O-ring between the cam cap's and head or under the head gasket...any comments or tips would be appreciated.
Old Aug 1, 2007 | 07:56 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: spark plugs drenched in oil (atarigamer01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atarigamer01 &raquo;</TD></TR><TR><TD CLASS="quote"> So Im thinking its the O-ring between the cam cap's and head </TD></TR></TABLE>
Ding ding ding! That would be your next area to check out.
Old Aug 1, 2007 | 08:30 AM
Default Re: spark plugs drenched in oil (wiZCo)
Would this have been the reason it shut down? Aside from new o rings, Im assuming I should get new spark plugs also...maybe?
Old Aug 1, 2007 | 10:10 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atarigamer01 &raquo;</TD></TR><TR><TD CLASS="quote">Would this have been the reason it shut down? Aside from new o rings, Im assuming I should get new spark plugs also...maybe?</TD></TR></TABLE>
Well, if they're drenched with oil, chances are there's weak spark between the plugs and wires. Once you've stopped the leak, replace both the wires and plugs as well.
Old Aug 1, 2007 | 10:26 AM
Sounds good to me...dude Im a little ashamed to admit this but I took it to pep boys (I broke down right next to it practically) and they said it was the timing belt...wtf?! In short dont take your car to pep boys! Ill get that stuff for my car and keep you posted.
Old Aug 1, 2007 | 11:32 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atarigamer01 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds good to me...dude Im a little ashamed to admit this but I took it to pep boys (I broke down right next to it practically) and they said it was the timing belt...wtf?! In short dont take your car to pep boys! Ill get that stuff for my car and keep you posted.</TD></TR></TABLE>
Yikes. Probably was just trying to throw part names out there to sound like he knew what he was talking about.
Old Aug 1, 2007 | 12:25 PM
CRX Toad's Avatar
I like to refer to the wires being coated in oil as "chocolate lolly pops". And as stated O-rings.
Old Aug 2, 2007 | 05:28 PM
Well, I sealed it up, bought new spark plugs, and new plug cables...but still no start. Im getting an error code on the ecu that I wasnt getting before. The led light blinks 16 times. I looked it up and they said it was the fuel injection. Could that be the reason it wont start? It wants to start but it just wont kick over, you know? Could it be its just not getting enough gas?
Old Aug 2, 2007 | 05:58 PM
2slow4stock's Avatar
Do you know if your getting fuel? and also is your fuel pump priming when you put it on the "on" position?
Well check your injector clips who knows if one might of wiggled loose somehow...
Old Oct 17, 2007 | 10:51 AM
nokturnal_munkeeboy's Avatar
same boat here, do you guy think that timing could be a factor of oil in spake plugs
Old Oct 17, 2007 | 10:57 AM
megamanxlieu's Avatar
bump yo
Old Oct 17, 2007 | 10:58 AM
HT Chaplain's Avatar
Loved
make sure the timming belt didnt snap. you could have had oil in your spark plug tubes all along and just didnt know it untill it stopped running.
Old Oct 17, 2007 | 12:42 PM
Default Re: spark plugs drenched in oil (HT Chaplain)
before i left the shop i check everything out and there wasnt no oil in spark plugs, i might be my seals the cause that problem i hope there's no else wrong with my car
bwiissofly
Jun 5, 2013 10:24 PM
InvaderJim
Mar 8, 2009 05:42 PM
integra racr04
Jul 25, 2006 06:38 PM
Sean @ ESG
16
May 28, 2006 11:12 PM
drewcandraw
Jul 23, 2005 03:31 PM
