deckplated gsr need headstuds and belt issues any input?
Old Jul 31, 2007 | 08:39 PM
A train's Avatar
Default deckplated gsr need headstuds and belt issues any input?
where can i buy a head stud about 5/16 inch longer and im using a deckplated gsr block with a 5/16 inch deckplate im thinking of using and ls meziere block off with a gsr belt going to check it tommorow to see how the tensioner does with that belt setup! any input would be appriciated! thanks a gsr belt is normally used with a 22 tooth pump and the ls is 19 tooth i hope it will work running out of time!
Old Jul 31, 2007 | 10:50 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: deckplated gsr need headstuds and belt issues any input? (A train)
h22 belt......?
Old Aug 1, 2007 | 02:24 AM
DaveF's Avatar
Default Re: deckplated gsr need headstuds and belt issues any input? (2fast4u831)
Golden Eagle makes the stuff you need. they have an idler pulley for the water pump, that moves in a slot, so you can still use the oem belt. they also make longer head studs.
Old Aug 1, 2007 | 04:28 AM
Mikey3000's Avatar
man, i haven't heard of someone running a deckplate for long time.
Old Aug 1, 2007 | 06:12 AM
f@sth@tch89's Avatar
Default Re: deckplated gsr need headstuds and belt issues any input? (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">man, i haven't heard of someone running a deckplate for long time. </TD></TR></TABLE>
i was thinking the same thing...wow. thats a throw back right there.
Good luck. im sure some how people can get those b-series into the 9's again and have it be consistant.
Old Aug 1, 2007 | 08:35 AM
allmotorhatch's Avatar
Default Re: deckplated gsr need headstuds and belt issues any input? (f@sth@tch89)
I had a deckplate B series. I got the headstuds from Golden Eagle, I think the timing belt was from a Ford/ztec motor.
Old Aug 1, 2007 | 01:59 PM
A train's Avatar
its a nice little motor, and im hoping to get over 300 hp and over 200 ft lbs which will get car in to the low tens who nows maybe a high nine we have all the other mixins but we just need to get this to work correctly!
Old Aug 1, 2007 | 06:05 PM
DaveF's Avatar
call golden eagle !
GearheadzAuto
Jan 3, 2008 07:58 AM
Ruben19
Jan 4, 2006 11:13 PM
Ruben19
Jan 4, 2006 11:05 PM
GEN2INTEG619
Mar 24, 2005 08:39 PM
playboyace35
Jun 25, 2004 12:14 AM
