should i run coolant to my TE04h? and what radiator to use?
Old Jul 31, 2007 | 08:31 PM
chunkybs's Avatar
Default should i run coolant to my TE04h? and what radiator to use?
i have a TE04H on my Z6, i have heard conflicting things about running coolant to it. should i do it or not?
and also, when i'm on the highway the car runs very hot, would i get better cooling if i used a teg full size radiator or a thicker aluminum half size one.
Old Jul 31, 2007 | 08:41 PM
AWDstylez's Avatar
No need for coolant lines. Those are for people to lazy or cheap for turbo timers.
Old Jul 31, 2007 | 08:46 PM
numbnuts22715's Avatar
Default Re: should i run coolant to my TE04h? and what radiator to use? (chunkybs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs &raquo;</TD></TR><TR><TD CLASS="quote">i have a TE04H on my Z6, i have heard conflicting things about running coolant to it. should i do it or not?
and also, when i'm on the highway the car runs very hot, would i get better cooling if i used a teg full size radiator or a thicker aluminum half size one. </TD></TR></TABLE>
a dual core with a couple slim fans with a higher flow rating than stock should be alright.
Id also recommend wrapping the downpipe and whatever else you can with header wrap or something like that.
Old Aug 1, 2007 | 09:35 AM
chunkybs's Avatar
my DP is already wrapped.
Old Aug 1, 2007 | 09:44 AM
bigbadboy's Avatar
i would def use the water lines. and get a thicker radiator and a good fan and u'll be set
Dm914
Jun 25, 2015 05:31 PM
imationdawg
Jul 18, 2009 08:34 AM
misterdopey
Jun 19, 2008 10:51 AM
hangac1093
Jun 3, 2007 06:16 AM
Mr_Moos
Aug 17, 2005 08:06 AM
