need info ABS vs non-ABS wheel hubs & bearings for civic / integra antilock brakes
Old Jul 31, 2007 | 07:32 PM
6SPD_EK's Avatar
Default need info ABS vs non-ABS wheel hubs & bearings for civic / integra antilock brakes
Trying to get all my ducks in a row here & need help
most common brake swap is integra/civic ex.... a large percentage were originally antilock braking system.
there are different part # for front & rear hubs & bearings for the same brakes depending if they are ABS or non ABS.
question 1.) are the bearings & therefore the (inside of) the hubs different sizes? I assume there is somesort of magenetic pickup or something in the bearings for ABS system - correct or no?
question #2) if they are different sizes & I want new ones (both bearings & hubs) can I just get non-abs bearings with non-abs hubs? if i needed just bearings i would go with abs bearings but the rears are all sold as a hub/bearing assembly
Old Aug 1, 2007 | 03:24 AM
6SPD_EK's Avatar
Default Re: need info ABS vs non-ABS wheel hubs & bearings for civic / integra antilock brakes (6SPD_EK)
bump -someone must know
Old Aug 21, 2008 | 01:22 PM
6SPD_EK's Avatar
found this but still need more info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darrinbrewer &raquo;</TD></TR><TR><TD CLASS="quote">did some research on parts sites...
civic dx is 2.874 OD 1.4961 ID
integra is 3.1102 OD 1.6929ID
so, i have a civic dx knuckle, and ex abs(integra siz brakes) knuckles
axles that need civic knuckles..but i want to use bigger brakes
it sucks!</TD></TR></TABLE>
what are civic ex/si (abs) bearings?
jason_SIR
Mar 25, 2014 01:49 PM
travisr138
Suspension & Brakes
Jan 25, 2009 06:57 PM
JCracer723
Jul 6, 2008 05:10 PM
6SPD_EK
Aug 7, 2007 12:50 PM
wrx'n you
Aug 28, 2006 09:38 AM
