Failed Omnipower bushing. What are my options?
Old Jul 31, 2007 | 04:04 PM
Dartanian's Avatar
Default Failed Omnipower bushing. What are my options?
After having these pile of crap Omnipower LCA's on for less than a year, the bushings have **** the bed.
Are these bushings the same size as OEM? I would prefer to replace with an OEM bushing. If that isn't an option, I guess I will be looking for some OEM LCA's.
Old Jul 31, 2007 | 04:41 PM
MrDomino's Avatar
out of dumb luck i just happened to be looking at these in another window
http://store.summitracing.com/...rstop
edit: Energy Suspension Rear Trailing Arm Bushing Sets
Red Bushings are reg. Polyurethane DONT have graphite
Black Bushings are Polyurethane that have graphite in them to help keep them lubed
both colors are the same product with the exception of the graphite
Old Jul 31, 2007 | 09:19 PM
Dartanian's Avatar
Default Re: (MrDomino)
Thanks.
Unless I can buy just those bushings from ES, I would rather go OEM. I just wanted to make sure that I could use OEM sized bushings or would I have to order special ones from Omnipower.
Old Jul 31, 2007 | 09:52 PM
MatterMatt's Avatar
That's fine, but his trailing arm bushings are not bad, its the shock mount bushing in the rear lower control arm that is bad/pictured. Two different things. You need the rear upper and lower shock bushings (have to get uppers with the lowers in those kits). I'm pretty sure you can get the oem control arm busings specifically without the upper shock bushings.
Old Jul 31, 2007 | 10:08 PM
Dartanian's Avatar
Default Re: (MatterMatt)
Alright, thanks.
I'll see if I can order some OEM ones right now. If they fit, great. If not, I will be swapping LCAs with a stock pair.
Old Jul 31, 2007 | 11:29 PM
4nmusle 2.1's Avatar
Default Re: (Dartanian)
dude you can go out and order yourself some red bushings from energy suspension they sell replacements and they r great ........ 1 small probelm they r so stiff you will need to have them pressed into the arm
Old Aug 1, 2007 | 12:19 AM
RaceMyGhost's Avatar
Default Re: (4nmusle 2.1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4nmusle 2.1 &raquo;</TD></TR><TR><TD CLASS="quote">dude you can go out and order yourself some red bushings from energy suspension they sell replacements and they r great ........ 1 small probelm they r so stiff you will need to have them pressed into the arm </TD></TR></TABLE>
umm....? you'll have to press in the OEM buhsings aswell....
Old Aug 1, 2007 | 01:03 AM
Kyle R's Avatar
Default Re: (RaceMyGhost)
Old Aug 1, 2007 | 03:25 AM
MrDomino's Avatar
Default Re: (herecomesboost)
if you can find the OEM bushings for a decent price then go with it if thats what you want
there are bushings for everything basically on that site i showed you- just look around
Old Aug 1, 2007 | 05:48 AM
vladd's Avatar
aftermarket bushings will disintegrate over time, unlike oem. for a dd i'd stick with oem.
Old Aug 1, 2007 | 06:52 AM
MrDomino's Avatar
Default Re: (vladd)
from what the description on the one site says it sounds like the polyurethane bushings hold up better than the oem rubber ones
Old Aug 1, 2007 | 06:54 AM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrDomino &raquo;</TD></TR><TR><TD CLASS="quote">from what the description on the one site says it sounds like the polyurethane bushings hold up better than the oem rubber ones</TD></TR></TABLE>
look up the post by patrick94gsr regarding his urethane shifter bushing. that thread had links to other posts with similar info; the urethane bushings don't last as long as oem. while oem ones will just shrink and soften with age the urethane will crumble.
Old Aug 1, 2007 | 06:59 AM
Dartanian's Avatar
I'm not really hot on polyurethane. I have it elsewhere and it squeaks too much. I don't think this bushing would be that affected by a stiffer bushing anyway. So, I ordered a pair of OEM bushings instead.
Thanks for the help guys.
Old Aug 1, 2007 | 09:02 AM
MrDomino's Avatar
Default Re: (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd &raquo;</TD></TR><TR><TD CLASS="quote">
look up the post by patrick94gsr regarding his urethane shifter bushing. that thread had links to other posts with similar info; the urethane bushings don't last as long as oem. while oem ones will just shrink and soften with age the urethane will crumble.</TD></TR></TABLE>
I tried to search and it said it was an invalid username
I'd really like to know because I was going to order ureth. shift bushings tonight but id like to read about this guy's experience before I do it
Old Aug 1, 2007 | 09:23 AM
KaBlookie's Avatar
did you take measurements to make sure that the bushings in the omni LCAs are the same size as OEM before buying the OEM ones? they very well might be different...
Old Aug 1, 2007 | 10:46 AM
Dartanian's Avatar
I'd really like to know because I was going to order ureth. shift bushings tonight but id like to read about this guy's experience before I do it</TD></TR></TABLE>
I've been running polyurethane shifter bushings for a couple years now. The 3" exhaust comes pretty close to them but they stand up to the heat well. I would recommend them over stock rubber ones any day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaBlookie &raquo;</TD></TR><TR><TD CLASS="quote">did you take measurements to make sure that the bushings in the omni LCAs are the same size as OEM before buying the OEM ones? they very well might be different...</TD></TR></TABLE>
That was really the point of this thread and my original question. There is no dealership within 300 miles, so I have to order the OEM bushings online. If I had a OEM bushing handy, I would have measured it and never made this thread in the first place.
Old Aug 1, 2007 | 12:19 PM
MrDomino's Avatar
email omnipower they should be able to tell you really quick
i got yelled at (im in corporate housing for the summer) and they sent me a nasty letter just for having jack stands in my garage (apparently i cant even change tires in my garage or they can evict me) otherwise id go measure it for you
omnipower may also be able to sell you replacement bushings so thats a possibility
sorry i didnt answer your question
Old Aug 1, 2007 | 03:38 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrDomino &raquo;</TD></TR><TR><TD CLASS="quote">email omnipower they should be able to tell you really quick
sorry i didnt answer your question </TD></TR></TABLE>
I appreciate the help.
I don't want replacement bushings from omnipower. It would be stupid to replace this pile of crap bushing with another pile of crap bushing. Either the OEM bushing fits or I am reverting back to OEM LCA's and selling these.
Old Aug 1, 2007 | 07:45 PM
vladd's Avatar
my bad, the username was actually patrickgsr94. anyway, here's his thread https://honda-tech.com/zerothread?id=1976512 . i have urethane shifter bushings and engine mount inserts and was thinking about getting all the urethane suspension bushings till i saw that thread. i'm not gonna take the chance of all the suspension bushings falling apart and having to redo everything. if the shifter bushings fall apart i'll just get new oem ones.
boxeocampeon
Suspension & Brakes
Apr 27, 2010 06:12 AM
philosofy1
12
Oct 29, 2007 01:08 PM
Biggmike92vx
10
Jun 3, 2007 09:06 PM
clarkekent13
Suspension & Brakes
Jul 25, 2005 07:57 PM
Eyewitness
18
Aug 27, 2003 07:15 PM
