B18B w/ B16 head NO vtec
is the b16 head better flowing than the LS head? if it does, could u put it on a LS block but not hook up vtec and do the oil lines so it would be a simpler, more reliable job? just a thought...
If you're not utilizing the VTEC cams, then there's no point in using the B16 head. Output is a combination of everything: cams/head/valve/timing/etc.
Also, I'm pretty sure the low cams have less flow than a regular B18b head anyways...so what's the use if you're not utilizing VTEC? Well, you can get Toda's VTEC killer cams, but that's beyond the scope of this discussion.
Touge Tuning
Jan 17, 2005 08:32 AM
