5 lug ?
Old Jul 31, 2007 | 12:02 PM
ILCD5's Avatar
Default 5 lug ?
I was thinking about doing a 5 lug conversion on my EF, but was told I might need different knuckles. I tried to do a search, but found no info. Does anyone know what parts I would need to do this swap? Thanks.
Old Jul 31, 2007 | 12:14 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 5 lug ? (ILCD5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILCD5 &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking about doing a 5 lug conversion on my EF, but was told I might need different knuckles. I tried to do a search, but found no info. Does anyone know what parts I would need to do this swap? Thanks.</TD></TR></TABLE>
There is a thread by "smokinsax" (I think) on here on how to do the ITR 5-lug conversion. Try searching for threads by him.
Old Jul 31, 2007 | 04:15 PM
ILCD5's Avatar
I only found 1 thread by him, but its for some door panel conversion or something.
Old Jul 31, 2007 | 05:22 PM
Wes V's Avatar
Default Re: (ILCD5)
There was a page at the FF squad web site, but it looks like the site is down.
As I recall, the rear is an easy swap using ITR hubs and brakes.
The front is an issue and I know that he (Jason?) took new ITR hubs and had a machine shop turn them down so that they could be pressed into SI bearings. I'm not sure, but I think he was using 4 door EX knuckles or maybe DA knuckles in order to get the caliper to bolt up.
The ITR brakes are better than the DA ones (a common swap, which is what I have), but I don't think it's worth the cost.
You have to use 15" rims.
The only reason for doing it in my mind is for the "look" of 5 lug rims. I'd do it if I was trying to impress others.
Wes
Old Jul 31, 2007 | 07:04 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (ILCD5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILCD5 &raquo;</TD></TR><TR><TD CLASS="quote">I only found 1 thread by him, but its for some door panel conversion or something.</TD></TR></TABLE>
Maybe he was one of the people that did it. Try searching "itr lug conversion" when search comes back up.
Old Jul 31, 2007 | 10:05 PM
ektahj's Avatar
Five lug eh? its pretty nice, but not so at times.
Old Sep 8, 2007 | 09:49 PM
GraphiteAccord's Avatar
Default Re: 5 lug ? (ektahj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ektahj &raquo;</TD></TR><TR><TD CLASS="quote">Five lug eh? its pretty nice, but not so at times.</TD></TR></TABLE>
why not? mine was great....in every way.
Old Sep 9, 2007 | 04:40 AM
CRX Toad's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
Maybe he was one of the people that did it. Try searching "itr lug conversion" when search comes back up. </TD></TR></TABLE>
Smokinsax did it on his car but someone else started the thread. Your not crazy.
Old Sep 9, 2007 | 07:31 AM
~sp33~'s Avatar
EFB055
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">
. Your not crazy.</TD></TR></TABLE>
I wish i could be told that once in a while.
Old Sep 9, 2007 | 08:06 AM
BiG Chris's Avatar
you can use itr rear setup but for the front you use the DA knuckles and then get a ITR hub and it has to be milled down to fit the DA wheel bearing and its all gonna work i will look for the link as its on my other computer and ill post up the how to for ya.
Old Sep 9, 2007 | 08:16 AM
Junior Tech's Avatar
http://www.ff-squad.com/technet/how-to/5lug.ef-da/
Old Sep 9, 2007 | 08:20 AM
.Grimace's Avatar
footwork mastery
Default Re: (Junior Tech)
pm wu tang he he has done it.
Old Sep 9, 2007 | 10:49 AM
dr_latino999's Avatar
Default Re: (Gremice)
I have the measurement of a brand new DA/EX Hub around here somewhere, it is recommended though that you have one on hand for the machinist to measure before cutting down the ITR hubs.
93DALSVTEC
Feb 20, 2007 06:52 AM
campbuds
Jul 17, 2004 01:39 PM
CrAzyGsR101
Dec 5, 2003 01:06 PM
godnf8
Feb 9, 2003 10:47 PM
Jeff 360
36
Jul 9, 2002 10:30 PM
