h22 swap...not reving...
Old Jul 31, 2007 | 11:31 AM
1sickHonda's Avatar
Default h22 swap...not reving...
This is the deal..got a 97 intgra with a accord euro r swap..h2b..the motor starts and runs fine..but will not rev..its not throwing any codes that would cause it to do this..the only code that is showing is for iacv..but that won't cause it to not rev..im using the wire harness for the car..and an obd2a to obd1 jumper harness with a p28 hondata s200 chiped for h22...any ideas or suggestions would be very helpful..
Old Jul 31, 2007 | 11:44 AM
ladyfriend's Avatar
Default Re: h22 swap...not reving... (1sickHonda)
i had the same thing happen with the B20B in the DA, turned out to be the odb0 dizzy. changed it up to the odb1, re pinned it and it was fine.
Old Aug 1, 2007 | 04:21 AM
1sickHonda's Avatar
Default Re: h22 swap...not reving... (ladyfriend)
see thats what i origanlly thought..cause at first the car was only running on 2 cyls....it was sparking on all for but 2 and 4 weren't spray fuel..i swiched the injectors out with 1 and 3 and still the same prob..so i swiched the internals of the dist. with the internal of a b series vtec (obd2a)..now it runs fine but won't rev..so your saying still maybe distributor probs?
Old Aug 1, 2007 | 05:43 AM
ladyfriend's Avatar
so you can open the throttle and it still idles? or doen it stall?
Old Aug 1, 2007 | 09:43 AM
1sickHonda's Avatar
Default Re: (ladyfriend)
when i open the throttle the car will just shut off...i adjusted tps..still same thing..i am begining to think maybe bad ecu?
Old Aug 1, 2007 | 09:55 AM
BSeriesBallin's Avatar
I had same prob with my zc crx it was the ecu
Old Aug 1, 2007 | 10:05 AM
1sickHonda's Avatar
Default Re: (BSeriesBallin)
i guess thats what im gonna try next...thanks alot for the suggestions..i let you guys know if it all works out..
Old Aug 14, 2007 | 12:59 PM
1sickHonda's Avatar
Default Re: (1sickHonda)
all right well..got the new ecu and still same problem..its begining to drive me nuts and this car needs to be on the road very soon..can it be a bad tps sensor? Even though no cel's are being thrown for it?
Old Aug 14, 2007 | 04:02 PM
Bense's Avatar
did you swap your tps + map sensor plugs?
Old Aug 15, 2007 | 05:51 AM
1sickHonda's Avatar
Default Re: (Bense)
the b-series harness plugs aren't the same for the h series sensors..i don't quit get what your saying on that?
Old Aug 15, 2007 | 06:58 AM
Bense's Avatar
on some hondas, the tps + map sensors have the same plugs as each other. They are also near each other. sometimes when we do swaps we get them mixed up. See if you can take the plug that's plugged into the map sensor and plug it into the TPS. And vice versa
Old Aug 15, 2007 | 09:08 AM
1sickHonda's Avatar
Default Re: (Bense)
agh..gotcha..i will try it and see if it does anything...
Old Aug 15, 2007 | 10:01 AM
1sickHonda's Avatar
lol..ok i offically feel pretty dumb right now...your the man Bense...switched the two around and it revs like a beast! lol..i really appreciate al the help from everyone..gonna get before and after and during the swap pics up soon..look forward to the accord euro r h2b 97 type r soon!
Old Aug 15, 2007 | 10:20 AM
Bense's Avatar
Old Aug 15, 2007 | 10:29 AM
Bense's Avatar
Default Re: (Bense)
and a big
for a H2B in South Carolina
Old Aug 16, 2007 | 05:22 AM
1sickHonda's Avatar
Default Re: (Bense)
HAHA..thats whats up...drove the car last night for the first time last night..
open header + h22 euro r + (h2b) usdm itr trans = lots of fun!!
Old Aug 16, 2007 | 08:06 AM
2fastGSR's Avatar
King of the One Liners
Bense for president
Cd5lyf
Sep 28, 2017 02:15 PM
hatchdrvr
Dec 12, 2011 06:50 AM
LiL JoN
Mar 23, 2008 03:47 PM
97itr101
Jul 24, 2007 06:21 PM
Blown90hatcH
Jun 30, 2002 07:28 AM
