Valve lash adjustment Need help please......
Old Jul 31, 2007 | 11:13 AM
godzhand's Avatar
Default Valve lash problem Someone please help me......
I decided to do a valve adjustment after I had to replace my timing tensioner. I read up on it got the proper feeler gauges INTAKE: 0.006" - 0.007"
EXHAUST: 0.007" - 0.008"
I read up when you are doing it 0.007 should have slight drag too it but the 0.008 should not fit when your done so I did it exactly as I read it online but no luck at all sounds horrible what am I doing wrong????
I have a B16a head with Type r cams I don't believe that makes any difference someone if you have any advice at all please post away......its not the timing as well its dead on for anyone who might think thats my problem.
Modified by godzhand at 3:42 PM 7/31/2007
Old Jul 31, 2007 | 11:30 AM
climb_on's Avatar
Default Re: Valve lash adjustment Need help please...... (godzhand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godzhand &raquo;</TD></TR><TR><TD CLASS="quote">
what exacly are you having trouble with?
i did mine no too long ago so i might be able to help you out if your more specific
Old Jul 31, 2007 | 12:08 PM
goota's Avatar
its kinda hot in florida isnt it? you sure your engine is getting cold enough ( &lt;100F )
Old Jul 31, 2007 | 12:18 PM
godzhand's Avatar
Default Re: (goota)
yeah its been sitting in my garage for 3 days with the valve cover off and the hood open I think thats more than enough time...
Old Jul 31, 2007 | 12:24 PM
godzhand's Avatar
Ok the reason I first wanted too do my valves was because they were getting louder and louder I did a leak down test only 6-8% loss in each cylinder so I was pretty suprised after boosting it for over a month but I built the motor for a while but I have never learned how too do a valve lash adjustment figured it would be fairly simple. I also noticed my timing was a little bit off after re doing it a month ago because My tensioner bolt stripped out, after that first timing I knew it was not dead on because My car would die if I did not keep the timing fully advanced so I decided to get a new tensioner redo the timing and its dead on perfect. But then I wanted to do the valves since they were ticking and its really annoying getting louder and louder so I did it and I guess I threw them off real bad because it wont idle right and sounds like crap ticking real bad smells like a lot of fuel is dumping through my exhaust.....?
Old Jul 31, 2007 | 12:29 PM
godzhand's Avatar
Default Re: (godzhand)
and the entire valve train is fairly new only about 3 months ago I got it out of the machine shop I was worried about hitting valves when my tensioner stripped lose but the vtec motors have more valve clearance I was not in vtec when it slipped and im running 8:1 comp pistons so there was not damage done....
Old Jul 31, 2007 | 02:43 PM
godzhand's Avatar
Anyone?
avaldez
May 28, 2008 07:50 PM
Nsane
Jun 23, 2006 08:10 AM
kpop
Jun 3, 2006 03:04 PM
milano2kdc2
May 17, 2005 08:42 PM
delsol93guy
Oct 12, 2004 07:06 AM
