b16 lots of noise after valve adjustment
Old 06-03-2006, 11:43 AM
kpop's Avatar
Default b16 lots of noise after valve adjustment
After doing the adjustment the first time set the valve specs .006 intake .007 exhaust and started it up and now theres alot of clacking noises on idle and driving. I made sure the motor was cold I cant understand where a problem might have occured. I just finished doing the adjustment 3 times. Can anyone help??
the manual says there should be a slight drag. anyone who has alot of experience adjusting valves please help. I hope nothing major has happened. Thanks guys
Old 06-03-2006, 01:08 PM
EG civic's Avatar
Default Re: b16 lots of noise after valve adjustment (kpop)
r u sure u tightened them down enough? usually a clacking sound indicates a loose valve.
Old 06-03-2006, 01:18 PM
kpop's Avatar
Default Re: b16 lots of noise after valve adjustment (EG civic)
thats what im stuck on im not sure how tight it needs to be. It felt like it had a slight drag to it. i can loosen or tighten it and i still feel a slight drag. anything else?
thanks again guys
Old 06-03-2006, 01:26 PM
imadigitalgod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpop &raquo;</TD></TR><TR><TD CLASS="quote">thats what im stuck on im not sure how tight it needs to be. It felt like it had a slight drag to it. i can loosen or tighten it and i still feel a slight drag. anything else?
thanks again guys </TD></TR></TABLE>
Im my helms manual it says the lock bolts have 13ft/lbs of torque for the d16Y8 engine, i cant imagine y it would b any different on a B16 tho.
Old 06-03-2006, 01:30 PM
kpop's Avatar
Default Re: b16 lots of noise after valve adjustment (imadigitalgod)
what about when you use the feeler and drag it back and forth does anyone kno if its suppose to feel a lil bit on the tight side? or should it glide back and forth with ease.
Old 06-03-2006, 01:33 PM
fmrprojects's Avatar
u sure you did it in the correct order. its suppose to be 1, 3, 4, 2 and you have to put the cylinder to TDC before you adjust the valves
Old 06-03-2006, 01:37 PM
kpop's Avatar
Default Re: b16 lots of noise after valve adjustment (fmrprojects)
i started by setting the crank to tdc adjusted #1 cylinder then cylinder#3 turned the up marks to the 9 o'clock pos, then #4 turned the up marks to 6'oclock, then #2 turned to 3'oclock pos. i assume this is the correct order please correct me if this is wrong. thanks
Old 06-03-2006, 03:04 PM
kpop's Avatar
bump
RotaryPWR
17
08-28-2009 11:15 AM
nello a.
08-17-2009 10:59 PM
ZCSp0ngeR
08-05-2009 11:38 AM
BlueJdm
07-25-2007 03:06 PM
Nsane
06-23-2006 08:10 AM
Quick Reply: b16 lots of noise after valve adjustment
