Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
i bought a 7.5 inch tach, i need to know which wire to splice...
Old Jul 31, 2007 | 11:10 AM
fventura03's Avatar
Default i bought a 7.5 inch tach, i need to know which wire to splice...
just as the topic says, bought a tach w/shift light, need to know which wire i need to tap into to get my rpms reading?
thanks guys. i searched but only found threads that told me to search more,
Old Jul 31, 2007 | 11:11 AM
daddy's Avatar
Default Re: i bought a 7.5 inch tach, i need to know which wire to splice... (fventura03)
do you have a factory tach too?
Old Jul 31, 2007 | 11:12 AM
fventura03's Avatar
yes
Old Jul 31, 2007 | 11:26 AM
jivi's Avatar
Default Re: (fventura03)
ey freddy here's what I got, gauge cluster connectors. HTH
GREEN Connector:
Blue: From ECM/PCM, Tach input signal
White/Red: Constant 12 v +
Yellow: Switched 12V+
Blue/White: From ECM/PCM And VSS input signal
Yellow/Black: From fuel level sending unit
White/Green: From multiplex control unit
Black: Ground
Pink: (Canada Vehicles only) Washer fluid level switch
White/Blue: (Canada Vehicles only) DRL Control unit
Black/Yellow: Security control unit
Blue/Yellow: Cruise control unit
Pink/Blue: OPDS unit (Side airbags)
BLUE Connector:
Black: Ground
green/orange: From ECM/PCM
Blue/Red: From ABS Control unit
Pink: From SRS unit
Red/Black: Supplies 12V+ for dash backlights
Red: Supplies switched ground for dash lights
Green/Red: Left turn signal indicator
Green/Yellow: Right turn signal indicator
Red/Blue: Combination light switch
Blue/Orange: Immobilizer control unit
Red/Yellow: From no 15 fuse under hood
White/Red: From no 9 fuse under hood
Yellow/Red: From oil pres switch
Old Jul 31, 2007 | 11:32 AM
sil04ver's Avatar
7.5? thats huge! that writeup should help, mine took about 25 minutes.
Old Jul 31, 2007 | 11:33 AM
jivi's Avatar
Default Re: (sil04ver)
and where did you tap the sender or the input?
Old Jul 31, 2007 | 12:06 PM
sujak's Avatar
you're a ricer freddy
Old Jul 31, 2007 | 05:15 PM
Honda Rules's Avatar
a tach.......shouldve of just gotten the shift light
Old Jul 31, 2007 | 06:00 PM
Harlowe's Avatar
Function>Fashion
He's kidding I'm sure
Old Jul 31, 2007 | 06:13 PM
boliver shagnasty's Avatar
Default Re: (sujak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sujak &raquo;</TD></TR><TR><TD CLASS="quote">you're a ricer freddy</TD></TR></TABLE>
I will show you and freddy what a ricer really is
Old Jul 31, 2007 | 06:40 PM
jivi's Avatar
Default Re: (Boosted D)
nope, freddy made a thread for me lol. thanks freddy .
98vtec
Feb 19, 2008 10:37 AM
Kyssrt-4
Apr 6, 2005 10:28 PM
99blackcivicSi
Apr 18, 2004 01:44 PM
LS stretch
Jul 30, 2003 12:41 PM
solohatch
Dec 28, 2002 02:00 AM
