lsu-4 wideband sensor for k20a???
will this sensor work with the kpro?????is there such lsu-4 sensor for the k20a???? can i used this for wideband tuning on my k20a???? need lots of help... thanks!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyk20 »</TD></TR><TR><TD CLASS="quote">will this sensor work with the kpro?????is there such lsu-4 sensor for the k20a???? can i used this for wideband tuning on my k20a???? need lots of help... thanks!!!</TD></TR></TABLE>
Not directly with kpro, but you can definally use it. you need to get a wideband that uses that sensor. then use the signal wire from the wideband into kpro.
you need to but an aftermarket wideband system with a 5 volt anolog output. you then wire that 5 volt output to the oxygen sensor input at the ecu.
2009HondaAccord
Feb 18, 2018 06:41 PM
bopbop93030
Audio / Security / Video
Aug 14, 2009 06:15 AM
