JDM OBD2A B16A+OBD2A ITR ECU=DETENATION!!!!!!
Old Jul 30, 2007 | 11:23 PM
s0flyy56's Avatar
Default JDM OBD2A B16A+OBD2A ITR ECU=DETENATION!!!!!!
Someone told me that if iu use a OBD2A ITR ecu with my B16A that it will cause detonation due to its made for a 1.8 and the fact that it will give to much air and fuel so it wont run right...
Old Jul 30, 2007 | 11:33 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: JDM OBD2A B16A+OBD2A ITR ECU=DETENATION!!!!!! (s0flyy56)
that makes no sense.
You cant change the air coming into your engine with the ECU as the throttle is controlled by your foot and a cable.
The fuel has to match that air. Detonation occurs when there is not enough fuel.
The ITR runs richer than a B16A. You would have LESS of a chance of detonation with everything being the same.
Seeing as how the B16A is not as high compression as a B18C5, the timing advance (if any) provided by an ITR ecu will cause no problems.
The car will be safer with the ITR ECU than with the B16 ecu.
The only problem is that the ITR rev limit is set higher than the B16A rev limit. Watch how high you rev it. Although, I did rev my stock B16 to 9200RPM once. It held together. lol best sounds ever.
I would not recommend doing that.
Old Jul 30, 2007 | 11:39 PM
s0flyy56's Avatar
Default Re: JDM OBD2A B16A+OBD2A ITR ECU=DETENATION!!!!!! (B serious)
no homo but
I LOVE YOU!!!!
hahaha
wat does the vtec engage at with the ITR ecu????
Old Jul 31, 2007 | 12:02 AM
B serious's Avatar
im guessing 6k still since the B16A and the B18C5 are geared pretty much the same.
Man_EK9
Jun 23, 2007 11:28 AM
bobbo
Apr 28, 2005 02:29 PM
hybrid901
Apr 29, 2002 04:22 AM
