stock exhaust.....
Old Jun 10, 2002 | 10:18 PM
CM-R's Avatar
Default stock exhaust.....
Is it bad to run my car with a stock exhaust??...i have a drag 3 turbo kit....Is too much back pressure bad for my engine in some ways??....I have a CUT OUT y-pipe for my exhaust when i want to run but i close it up when i just drive around town....
Old Jun 10, 2002 | 11:34 PM
CM-R's Avatar
Default Re: stock exhaust..... (CM-R)
Come on guys no one has any info...i know the stock exhaust gives me less power, but does it have any side affects and cause problems for my turbo or engine??
Old Jun 11, 2002 | 12:34 AM
ion_four's Avatar
I don't see that it would cause any problems, except less power. Pretty slick to have that and the cut-out, though. I was thinking about doing that, but I've just got a Borla Turbo and re-did the piping, so it's not much louder than stock, looks stock, but sure flows better.
Old Jun 12, 2002 | 11:26 AM
CM-R's Avatar
Default Re: stock exhaust..... (ion_four)
Yea i thought so too just wanted to make sure....I'm going to be using a type-r axle back with 2.5 inch piping all the way to my cat...this is to make sure no problems arise....
Old Jun 12, 2002 | 11:39 AM
Etylorcen's Avatar
You'll just be slow...very slow and spool very late.
Old Jun 12, 2002 | 12:42 PM
01geeser's Avatar
New User
Default Re: stock exhaust..... (Etylorcen)
but increasing ur piping diameter will lower egt's
Old Aug 8, 2004 | 03:24 PM
Stewie's Avatar
Default Re: stock exhaust..... (01geeser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01geeser &raquo;</TD></TR><TR><TD CLASS="quote">but increasing ur piping diameter will lower egt's</TD></TR></TABLE>
Can anyone else confirm this???
I want to use a type r exhaust on my turbo setup for a bit because lack of funds, but I'm not looking forward to higher egt because of it.
Old Aug 9, 2004 | 05:02 AM
Stewie's Avatar
Default Re: stock exhaust..... (Stewie)
Old Aug 9, 2004 | 12:00 PM
Stewie's Avatar
free
U.S. Soldier
Mar 18, 2009 06:30 PM
civic_driver
Aug 28, 2005 02:06 PM
dajman94
Jan 18, 2005 04:18 PM
jdkornlp
Nov 8, 2003 10:01 AM
turbogsr13z
Sep 27, 2002 12:26 PM
