auto to manual. search is down.
Old Jul 30, 2007 | 08:26 PM
95lscivic's Avatar
Default auto to manual. search is down.
search won't work for me it's probably the server but i really need to find the auto to manual swap for an 88 sedan. somebody please help me out. i know that there is a thread better than the one in the faq.
Old Jul 30, 2007 | 08:31 PM
d16efsedan's Avatar
Default Re: auto to manual. search is down. (95lscivic)
google it man.what yr tranny are you using?88 tranny is different and i believe 89 is also diff then 90-91 are the same as in splines,so use whatever yr clutch as the tranny.wire up the reverse lights and there is a plug under your ebrake console with 2 big black wires you need to wire those together hope that helps
Old Jul 30, 2007 | 08:43 PM
95lscivic's Avatar
Default Re: auto to manual. search is down. (d16efsedan)
yeah i know i've been searching yahoo and google and i keep finding the same three threads. we're using a 90 transmission with a 90 clutch and flywheel. i knew that the transmissions were all different as the splines are not the same. but i was wondering mainly about the specific mounts i need. also would a engine and dash harness out of a manual dx crx all work if i wanted to use this instead of splicing into the harness intself as i have one available. thanks.
Old Jul 30, 2007 | 08:49 PM
d16efsedan's Avatar
you only need the rear tranny mount,you shouldnt need a harness at all i never had to change mine out when i did my auto to manual.
Old Jul 30, 2007 | 09:07 PM
RCautoworks's Avatar
http://hometown.aol.com/jrmupzaii/auto2man.html
Old Jul 31, 2007 | 02:32 PM
CR-V-tech's Avatar
Default Re: auto to manual. search is down. (RCautoworks)
bump
Old Jul 31, 2007 | 02:44 PM
Default Re: auto to manual. search is down. (CR-V-tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR-V-tech &raquo;</TD></TR><TR><TD CLASS="quote">bump </TD></TR></TABLE>
Why are you bumping it, I provided all you need to know. As for the harness goes, as long as its the same model it will work.
Old Jul 31, 2007 | 09:14 PM
MattyJ's Avatar
bump
Old Aug 1, 2007 | 06:08 AM
CRX Toad's Avatar
https://honda-tech.com/zerothread/1508680
Bsixteen_CRX
Oct 17, 2008 12:23 AM
wfocrx
Apr 21, 2006 09:11 AM
dxrex
Sep 1, 2004 02:05 PM
osuperjohno
May 14, 2004 09:59 AM
EG TYPE-R
16
Apr 30, 2003 09:45 PM
