questions about auto dx to manual swap (did a search)
Iam working on myy project 91' crx dx auto converting it to a 5speed d16z6.
Anyways, so far I have the shift linkage, pedal assembly, new manual replacement axles and passenger+tranny motor mounts out of a crx si.
I also bought a clutch kit+flywheel designed for a 90-91crx si.
lastly, I have found a a tranny out of a 89' crx si. Will all this stuff work together. The only difference between the 89 and 90-91 crx tranny is the clutch is a little bigger right? It should work is I have the clutch flywheel combo together? and the flywheel will work cause they are all the same from 88up right?
Re: questions about auto dx to manual swap (wfocrx)
As long as the splines on the axles match the new tranny and the wheel hubs you should be good. I know there was a year where the splines were different but for the life of me I cant remember which.
My auto to manual guide is at http://4gcivic.net but it sounds like you have covered all of the important parts. Just make sure you have a new starter for the manual and the rear mount also.
Best of luck to you.
urkcrx
10-23-2007 09:31 AM
