jdm B18C type R, bogs at low RPM
Old Jul 30, 2007 | 07:08 PM
BanEL's Avatar
Default jdm B18C type R, bogs at low RPM
swapped in the motor about a year ago... never had any problems with it yet... but lately noticed it but lately around 2000-3400 rpm, motor really seems to bog when i give it more than 50% throttle...
has anyone had this problem with the type r?
its a completely stock jdm type R swap 99 spec in an eg
search function is hooped
Old Jul 30, 2007 | 07:36 PM
HeikDiesel's Avatar
Default Re: jdm B18C type R, bogs at low RPM (BanEL)
what kinda exhaust system are you running?
Old Jul 31, 2007 | 09:15 PM
BanEL's Avatar
Default Re: jdm B18C type R, bogs at low RPM (HeikDiesel)
t1r 2.5" test pipe, t1r 2.5" midpipe, and a 2.5" axleback.
oh, and its using its stock obd2a ecu
Old Aug 1, 2007 | 05:08 PM
BanEL's Avatar
anyone suggestions?
Old Aug 4, 2007 | 11:01 PM
OldManEf's Avatar
I have a JDM Type r swap in my 1990 CRX, OBD2a as well. Bogging same as you from 2400-3500 rpm at light or partial throttle. I replaced cap, rotor, plugs, wires, fuel filter and it helped a bit, but not that much. However, I had a feeling it was fuel related. So I put a fuel pressure gauge on my car and found that my fuel pressure was low (measured at idle). Stock ITR fuel pressure should be 47-54 psi (vacuum hose disconnected) or 38-46 psi with vacuum connected. My car was 38psi with vacuum connected. This on the very low end of where it should be. I then purchased an AEM FPR and installed it, crank the fuel pressure to 54 psi (vacuum disconnected) and the car runs excellent. Fuel pressure gauge now reads 45psi with vacuum line connected. No more bogging at any RPM, WOT or not. Power is much smoother now and stronger. This was all with OEM Crx fuel pump. I just replaced my fuel pump with a Walbro 190 lph (for my peace of mind) to ensure the engine is getting enough fuel at high rpms. Lengthy response, but this fixed my problem so hope it fixes yours.
Modified by OldManEf at 12:18 AM 8/5/2007
Old Aug 5, 2007 | 08:55 AM
BanEL's Avatar
Default Re: jdm B18C type R, bogs at low RPM (OldManEf)
ahhh thanks for the response. definately gonna give that a try
Iceycrx
Jan 25, 2005 03:53 AM
p-boy
May 25, 2002 01:55 PM
comptechgsr2000
May 22, 2002 10:16 PM
Ladies Man
Jun 16, 2001 06:25 PM
