rear camber adjustment.
Old Jul 30, 2007 | 06:14 PM
RockWolf's Avatar
Default rear camber adjustment.
yeah since i installed my new suspention and droped it the car has a bad negative camber. So I went on the FAQ a saw that there was a simple adjustment. You just needed to install washers and longer bolts..
https://www.hondapartsdeals.co...B++30
number 31
yeah i would like to know the diameter of the bolt and the thread. for me to get it.
thx
Modified by RockWolf at 10:45 PM 7/30/2007
Old Jul 30, 2007 | 06:45 PM
HondaCivicSiR1's Avatar
Default Re: rear camber adjustment. (RockWolf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockWolf &raquo;</TD></TR><TR><TD CLASS="quote">yeah since i installed my new suspention and droped it the car has a bad negative camber. So I went on the FAQ a saw that there was a simple adjustment. You just needed to install washers and longer bolts..
number 31
thx
Modified by RockWolf at 10:33 PM 7/30/2007</TD></TR></TABLE>go back to where you found the info on the washer trick because the answer is there also for the bolts
Old Jul 30, 2007 | 06:47 PM
RockWolf's Avatar
Default Re: rear camber adjustment. (HondaCivicSiR1)
you sure? didnt find it in the thread https://honda-tech.com/zerothread?id=330624 and the link at the end is dead.
Old Jul 30, 2007 | 06:55 PM
look here https://honda-tech.com/zerothread/1508680
Old Jul 30, 2007 | 07:03 PM
RockWolf's Avatar
-_- can t find it. I am looking everywhere in suspension and cant find what i am looking for.
Old Jul 31, 2007 | 10:45 AM
Tyson's Avatar
for the money, just get omnipower rear shim kit.
http://www.omnipowerusa.com/product.asp?P_ID=126
btw, you really dont need to reduce the rear camber. just get an alignment to fix your toe. your misaligned toe is more critical than the camber.
brianmcivics
Suspension & Brakes
Feb 6, 2008 07:56 AM
pinks11
Suspension & Brakes
Dec 7, 2007 06:43 AM
classciv
Aug 28, 2005 12:54 PM
xXx Justin xXx
26
Oct 22, 2004 03:41 PM
FourthGenHatch
11
Oct 1, 2002 07:00 PM
