STRANGE TIRE WEAR (PLS. HELP)
Old Jul 30, 2007 | 05:55 PM
Hiroshima_VTi-S's Avatar
Default STRANGE TIRE WEAR (PLS. HELP)
I have the BF Goodrich G-Force 205/45/16 my car is really low with K*Sport Coilovers... on my DC2
The issue... my tires were all evenly tread wear, I started to noticed my front passenger tire is "REALLY" wearing FAST!!!..... the wear is in the middle of the tire... NOT inner camber or outer camber....
my 3 tires are now 45% and the other tire is zero tread it looks like a drag slick hehe
some people say i have too much air in the tire...
some say alignment....
what could be the problem?
thanks!
Old Jul 30, 2007 | 06:37 PM
Jdmtuned's Avatar
From: Long Beach/Riverside, California, United States
your tires maybe over inflated. people usually set they're tire pressure at 32-35psi
Old Jul 30, 2007 | 06:40 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: STRANGE TIRE WEAR (Hiroshima_VTi-S)
Yes, tread wearing in the middle of the tire more than both edges is typically a symptom of overinflation.
Other possibilities are an alignment or suspension problem.
Old Jul 30, 2007 | 06:46 PM
old man neri's Avatar
Default Re: STRANGE TIRE WEAR (nsxtasy)
Side note, I have seen people useing the pressure gauges located on the pumping stations at gas stations or using these little pencil type pressure guages. I researched these and it turns out they are really not that reliable. I recommend that you get a dial kind. Something that looks like this. Don't be cheap and try to save $0.75, get a decent one. It should not be expensive as well.
Old Jul 30, 2007 | 07:31 PM
thanks i hope its tire over inflation....
Old Aug 1, 2007 | 02:17 AM
alexisthemovie's Avatar
i doubt it's overinflation. if the tire is going insanely fast, then it's got to be out of spec toe.
Old Aug 1, 2007 | 06:29 AM
pomansouth01's Avatar
Ginger Kid
has the car ever been wrecked??
Old Aug 1, 2007 | 09:38 AM
Default Re: (pomansouth01)
no it hasnt been wreck, frame is fine and straight....anyways whats the spec toe?
Old Aug 1, 2007 | 12:37 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Hiroshima_VTi-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hiroshima_VTi-S &raquo;</TD></TR><TR><TD CLASS="quote">no it hasnt been wreck, frame is fine and straight....anyways whats the spec toe? </TD></TR></TABLE>
That's part of the alignment. Get it done at a shop that has all the right equipment to do a complete alignment.
Old Aug 1, 2007 | 02:26 PM
egb18c5's Avatar
Default Re: (nsxtasy)
over-inflation, and if its wearing out too much then u have a toe problem. get a alignment
beanbag
Apr 5, 2009 09:55 PM
jordan_rael_420
Feb 21, 2009 06:08 AM
lowRIDAH
12
Jul 26, 2004 03:16 PM
SOHCMAN
Jan 15, 2004 08:11 AM
JeffS
Jul 27, 2002 08:08 PM
