shift linkage removal
Old Jun 10, 2002 | 09:50 PM
dontcare61776's Avatar
Default shift linkage removal
trying to unhook shift linkage from the tranny so i can pull a motor, b-series, i cant get the pin out that hooks the linkage to the tranny side.....anyone have any good methods to get this done?? also haveing trouble seperating the ball joint to get the axles out...whats the deal with that?? thanks for the help you all.
~nate
Old Jun 10, 2002 | 11:59 PM
Charles B.'s Avatar
Default Re: shift linkage removal (dontcare61776)
i think u need a 8 mm punch pin and a hammer
Old Jun 11, 2002 | 12:42 AM
Accord94DX's Avatar
Buy a pickle fork for the ball joints.
Old Jun 11, 2002 | 01:31 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: shift linkage removal (Accord94DX)
If I dont have a punch I use a 1/4 ratchet extension and hammer it out. On the ball joint I loosen up the bolt on the bottom of the ball joint and bang on the arm and it usually falls down.
art
Old Jun 11, 2002 | 03:54 AM
IdotheSHOCKER's Avatar
Default Re: shift linkage removal (SuperDuperEG)
Old Jun 11, 2002 | 05:59 AM
X2BOARD's Avatar
Default Re: shift linkage removal (Arturbo)
Wooden hammer is good for the ball joint.
Old Jun 11, 2002 | 06:09 AM
sackdz's Avatar
Default Re: shift linkage removal (X2BOARD)
Don't use a pickle fork unless you want to replace the boots, because you'll most likely tear them. Pick up a Pitman arm puller, available from Auto Zone, Pep Boys etc, it works like a charm. Just make sure you get it on straight so you don't damage the threads or the stud.
Dr.Fixit
Oct 22, 2013 12:42 AM
Matt_Jagg7
May 13, 2010 01:18 AM
stegon78
Jun 24, 2005 08:46 AM
sabertooth
Jan 9, 2004 10:23 PM
LoudAccord
Aug 12, 2002 11:10 AM
