Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Neg camber related to uneven brake pad wear
Old Jul 30, 2007 | 05:33 PM
Nighthawk R18's Avatar
Default Neg camber related to uneven brake pad wear
Started to hear some squeaking in my brakes after 8 months. took off my wheels and caliper and got to the brake pads. the outside pad is normal, however the inside pad is worn to the clip. so i cut half the clip off so its not touching the disc anymore but im like another month or 2 away from needing new pads (maybe hawk).
What puzzled me was that the inside pad was worn unevenly. the side of the pad that toward the top is more worn than the bottom side. i first thought this would be part of a camber issue but realized the whole brake assembly cambers in with the wheel?! so i have no idea. could this be an alignment problem? i got an alignment no longer than 2 months ago. this happen to anyone before?
Old Jul 31, 2007 | 06:08 PM
Default Re: Neg camber related to uneven brake pad wear (Nighthawk R18)
Old Jul 31, 2007 | 07:14 PM
Tadehi's Avatar
Schumacher '10 WDC
Camber should have no relation what so ever to the wearing of brake pads. Perhaps there was an issue with the manufacture of the pads or something else, but camber shouldn't be a problem.
Old Jul 31, 2007 | 08:47 PM
Default Re: Neg camber related to uneven brake pad wear (Tadehi)
thats what i was thinking. what do you suggest i do? i doubt warantee will cover it since all my suspension parts. i should just get new pads huh. ill wait to get an alignment until after i get rims and coils.
Old Jul 31, 2007 | 08:59 PM
Tadehi's Avatar
Schumacher '10 WDC
I don't think an alignment issue is your problem either, you may have just gotten a bad set of pads. Suspension changes will affect your braking, so it might just be that with your new setup you are putting a greater strain on your pads. Hence them needing to be replaced sooner. As far as pads go everyone seems to say that Hawk Performance Plus pads are really good, in fact I have yet to hear a complaint. Definitely wait till after you get rims and springs before doing an alignment. My car isn't lowered, but when I read the forums everyone says that they go for an alignment right after they do the drop. So if you can wait, hold off on the alignment otherwise you will be wasting X amount of dollars for one.
Old Jul 31, 2007 | 09:15 PM
that just about answers it. lol
thanks alot, you've been most kind
Old Jul 31, 2007 | 09:18 PM
Tadehi's Avatar
Schumacher '10 WDC
No prob.
Old Aug 30, 2007 | 07:29 PM
LsHoney84's Avatar
could it be you're caliper sticking?
Old Aug 31, 2007 | 06:57 AM
IT GUY's Avatar
Default Re: Neg camber related to uneven brake pad wear (LsHoney84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 &raquo;</TD></TR><TR><TD CLASS="quote">could it be you're caliper sticking?</TD></TR></TABLE>
would that wear just the top part of the pad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">
What puzzled me was that the inside pad was worn unevenly. the side of the pad that toward the top is more worn than the bottom side. </TD></TR></TABLE>
Old Aug 31, 2007 | 07:11 AM
Default Re: Neg camber related to uneven brake pad wear (IT GUY)
damn i still dont know. but i hope it doesnt happen with my new hawk pads.
Old Aug 31, 2007 | 07:15 AM
Type X's Avatar
how many miles on the car?
Some dealers will warranty certain items till about 10k after that its "wear an tear"
Old Aug 31, 2007 | 07:19 AM
Default Re: Neg camber related to uneven brake pad wear (Type X)
im at 19.2k
Old Sep 4, 2007 | 08:34 PM
LsHoney84's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY &raquo;</TD></TR><TR><TD CLASS="quote">
uneven brake wear is due to caliper seizing, slide pin/bolt (whatever you call it) seized.
So i guess in your situation the top part of the pad would wear out if the top pin/bolt is seized. i dont know, someone correct me if im wrong.
professorman
Oct 31, 2008 11:45 AM
ebonyrolla7
Dec 19, 2005 03:56 PM
eboniwoman
Jan 19, 2005 07:36 AM
whtdc2
Aug 13, 2002 04:27 AM
tC_Dragon
May 13, 2002 02:59 PM
Top
Follow Us
