which wheel bearing on integra brake swapped eg? abs application vs non-abs
Old Jul 30, 2007 | 03:40 PM
6SPD_EK's Avatar
Default which wheel bearing on integra brake swapped eg? abs application vs non-abs
if i get a integra brake swap how can I tell if it was from an ABS equipped donor car. even if am NOT running ABS do i need to get the bearing for ABS integra?
Old Jul 30, 2007 | 06:27 PM
6SPD_EK's Avatar
Default Re: which wheel bearing on integra brake swapped eg? abs application vs non-abs (6SPD_EK)
ok assuming its not an RS brake swap then its abs (i think) are the bearings different size?
for the rear can i just order the non-abs hub/bearing assembly?
Old Aug 7, 2007 | 11:41 AM
6SPD_EK's Avatar
someone must know
Old Aug 7, 2007 | 12:13 PM
94hatchling's Avatar
if it helps... when i check between an ABS equipped integra and a non-ABS equipped integra, i have two different part numbers concerning the rear hub assembly...
Part #'s:
Non-ABS - 42200-SR3-A06
ABS - 42200-SR3-A53
and the ABS unit is about $30 more than Non-ABS..... FYI
NOW, for the FRONT wheel bearings, they are the same part #. i, however, do not know if if makes a difference if it is ABS or non-ABS, i just know they are different part #'s when it comes to the rear hub assembly.
Free Bump for someone that knows for sure.....
Old Aug 7, 2007 | 12:21 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling &raquo;</TD></TR><TR><TD CLASS="quote">
Free Bump for someone that knows for sure.....</TD></TR></TABLE>
i was told that there is a difference in size between abs and non-abs.
the fronts do have the same part# 44300-S5A-004
the rear part# is different, the gsr is 42200-sr3-a53
the rs is 42200-sr3-a06.
if the set up you have is abs, it should have the mounts for the abs wire. also, i would just stick to getting abs parts just to play it safe.
Old Aug 7, 2007 | 12:40 PM
pk386's Avatar
the rear breaks, on the inner side of the hub will have a 'gear looking' ring around it
if it has it then it's ABS
speed ring = abs
no speed ring = no abs
and I'd get the bearing that matches your car just to be sure (should be same price or with in 10$ of each other)
Old Aug 7, 2007 | 12:50 PM
6SPD_EK's Avatar
Default Re: which wheel bearing on integra brake swapped eg? abs application vs non-abs (pk386)
hey - thanks guys.... you see brakes are ABS integra brakes going on a NON-ABS civic dx hatch. i will not be using abs
so i was hoping to save a few bucks & go non-abs hubs & bearings... I have got quite the project on my hands with a '94 eg (that will be receiving my k-swap) so I want everything like new from the get-go...
I know for the fronts if i don't replace the hubs I will go ABS bearings for piece of mind (just incase there is a bearing size difference. if i do replace the front hubs I will go with a civic/integra NON-abs combo
& actually for the rears there is substaintal savings to go non-abs hubs & bearings
hondatuner020
Oct 21, 2014 09:39 AM
alexg103
Feb 23, 2010 11:16 AM
youdontknowmeeither
Dec 20, 2006 08:50 PM
wrx'n you
Aug 28, 2006 09:38 AM
alexb16hb
Apr 3, 2006 01:42 PM
