How do I find out if I have LSD Transmission?
Old Jul 30, 2007 | 12:51 PM
EG6sir2seb's Avatar
Default How do I find out if I have LSD Transmission?
I don't know where to look or what to look for?
How can I find out if I have LSD transmission?
Thanks guys
Old Jul 30, 2007 | 12:55 PM
Coach McGuirk's Avatar
who peed in my canteen!?
Default Re: How do I find out if I have LSD Transmission? (EG6sir2seb)
what kind of car/engine do you have ?
Old Jul 30, 2007 | 01:02 PM
Tryin2Rip's Avatar
Default Re: How do I find out if I have LSD Transmission? (Coach McGuirk)
burnout
Old Jul 30, 2007 | 01:05 PM
bnut510's Avatar
Default Re: How do I find out if I have LSD Transmission? (Tryin2Rip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tryin2Rip &raquo;</TD></TR><TR><TD CLASS="quote">burnout </TD></TR></TABLE>
if both tires spin, u got lsd... if not, u got a peg leg
Old Jul 30, 2007 | 01:11 PM
95sloweg's Avatar
Default Re: How do I find out if I have LSD Transmission? (bnut510)
if you jack up your front of the car, put it in neutral, and spin one of the front tires, if the other tire spins the same way as the other one you got lsd if it goes the opposite way you dont got lsd. Or if you look where your axles go into your tranny and can see right through it then you got lsd if there is a bar through that hole you dont got lsd. i learned this from a thread that was posted a couple of days ago.
Old Jul 30, 2007 | 01:24 PM
justinCO's Avatar
Default Re: How do I find out if I have LSD Transmission? (95sloweg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sloweg &raquo;</TD></TR><TR><TD CLASS="quote">... Or if you look where your axles go into your tranny and can see right through it then you got lsd if there is a bar through that hole you dont got lsd...</TD></TR></TABLE>
slkleltlclh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sloweg &raquo;</TD></TR><TR><TD CLASS="quote">if you jack up your front of the car, put it in neutral, and spin one of the front tires, if the other tire spins the same way as the other one you got lsd if it goes the opposite way you dont got lsd. Or if you look where your axles go into your tranny and can see right through it then you got lsd if there is a bar through that hole you dont got lsd. i learned this from a thread that was posted a couple of days ago.</TD></TR></TABLE>NOT TRUE
my tranny is factory lsd HELICAL style and if i spin my front wheel one way the other spins the other way. only clutch style or "viscious" (spelling) style spin the same direction when spinning one wheel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bnut510 &raquo;</TD></TR><TR><TD CLASS="quote">
if both tires spin, u got lsd... if not, u got a peg leg </TD></TR></TABLE>
my single cam d series did NOT have lsd, and if i did a burnout BOTH my wheels DID spin, so this statement isnt true either
Old Jul 30, 2007 | 01:28 PM
bnut510's Avatar
Default Re: How do I find out if I have LSD Transmission? (slkleltlclh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slkleltlclh &raquo;</TD></TR><TR><TD CLASS="quote">my single cam d series did NOT have lsd, and if i did a burnout BOTH my wheels DID spin, so this statement isnt true either
did they spin evenly tho? sometimes they will both spin, but only for a little bit, unless one side is getting more traction than the other. if it does spin, it wont for long.
Old Jul 30, 2007 | 02:37 PM
one wheel spun for a little longer..but not by much...it still was a good amount for both wheels to spin all through 1st
Old Jul 30, 2007 | 03:33 PM
cibola's Avatar
Most of the reply's on this post are incorrect.
If your car is balanced and you are on flat pavement both tires will burnout the exact same amount.
Spinning tires when jacked up: open diffs and all LSD's will spin tires either one way or another, if only one tire spins you have bigger problems than wondering if you have an LSD or not.
You will have to remove your axles to find out if you have an LSD and even then that is not always true. but for 90% of the LSD's out there you should be able to LOOK STRAIGHT THROUGH and see the other side. If you can see through you have an LSD. If you cant you might but odds are you don't.
Old Jul 30, 2007 | 03:42 PM
Crx_Civic's Avatar
Default Re: How do I find out if I have LSD Transmission? (cibola)
so...what civic trannys did come stock with LSd...Any? is there a thread that tells that?
Old Jul 30, 2007 | 04:56 PM
teamworxek9's Avatar
cibola is correct.
Old Jul 30, 2007 | 04:59 PM
instrument's Avatar
put it on ebay
list it as having an lsd
after it's sold, if the buyer doesn't leave you negative feedback, then it did have lsd?
Old Jul 30, 2007 | 05:01 PM
EG6sir2seb's Avatar
Default Re: How do I find out if I have LSD Transmission? (Crx_Civic)
These are all helpful comments except for that ebay one.... but...I don't have the car yet. It's being imported from Japan, and the guy that's importing the car for me doesn't know how to determine but looking if it has LSD. Is there no written code or stamp on the transmission to tell if it has factory fitted lsd?
If not, and the car doesn't have an LSD, how much am I lookin at to buy one, and is it best to match the LSD with the clutch/flywheel/etc?
thank you
p.s. It's a JDM B16A in a 1994 EG6 SIR2
Modified by EG6sir2seb at 6:13 PM 7/30/2007
Old Jul 30, 2007 | 05:20 PM
b17a1db2's Avatar
take axles out. if you can see straight through the diff, then you have lsd, if you see a bar in it. then you have open...
calvinx29
Feb 15, 2006 12:05 PM
91crex
16
Jun 21, 2005 03:16 AM
.Ryan
12
Apr 3, 2005 06:57 PM
2lobes1engine
10
Apr 15, 2004 04:35 PM
Bulldogg83
Oct 27, 2003 11:04 PM
