LSD equipped?
Re: LSD equipped? (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">or you can pull the axles and look through the hole to tell.</TD></TR></TABLE>
The ONLY 100% method.
Former Sponsor
Re: LSD equipped? (2lobes1engine)
Jack the front of the car. Rotate one of the front tire and the other should rotate in the same direction. If it doens't...there is no LSD.
If you want to take the time to remove the axels go ahead. If you see a metal pin/small bar across the hole you don't have LSD.
Or do a burnout. If the burnout is long like 15 feet long...you probably have LSD.
Hope it helps.
Hope it helps.
Re: LSD equipped? (-Bionic-)
i the many other posts that have talked about this it has been determined that that is bullshit<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">Jack the front of the car. Rotate one of the front tire and the other should rotate in the same direction. If it doens't...there is no LSD.
Hope it helps. </TD></TR></TABLE>
do a search there is a lot of topics about this
Former Sponsor
Re: LSD equipped? (H22A EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A EG6 »</TD></TR><TR><TD CLASS="quote">i the many other posts that have talked about this it has been determined that that is bullshit
do a search there is a lot of topics about this </TD></TR></TABLE>
LOL...Are you speaking English?
What has been determined?
LOL...Are you speaking English?</TD></TR></TABLE>
meaning u dont know what the **** ur talkin bout
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lobes1engine »</TD></TR><TR><TD CLASS="quote">Does LSD make a significant enough difference, in handling and overall performance, to justify its price?</TD></TR></TABLE>
ooo **** yes LSD is the **** if you have ANY power at all.
use your brain. say your car puts down i dunno 125whp. that only goes to ONE WHEEL so that alot of grip for a tire to handle. now you have LSD you get power sent to BOTH tires and that 125whp is split
EG6sir2seb
14
07-30-2007 05:20 PM
tallblondkid
32
07-11-2004 08:36 AM
