Can oil return bung be aluminum, or need steel??
Old Jul 30, 2007 | 03:04 AM
BDogggUT34's Avatar
Default Can oil return bung be aluminum, or need steel??
I have a b18b that i stripped the oil drain bolt on, now it wont tighten or come out so i can change my oil. I'm gonna replace it, but need my -10an return bung. Jeg's has one (store right by my house) but it's aluminum and i believe the B18b pan is steel. Is this a problem? Do i NEED the steel one? I will be taking this to a regular car shop to have them weld this on. Thanks for the help
Old Jul 30, 2007 | 03:11 AM
Kyle R's Avatar
Default Re: Can oil return bung be aluminum, or need steel?? (BDogggUT34)
The oil pan is stamped steel. Are you going to weld the fitting in the new oil pan?
Old Jul 30, 2007 | 03:13 AM
BDogggUT34's Avatar
Default Re: Can oil return bung be aluminum, or need steel?? (herecomesboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by herecomesboost &raquo;</TD></TR><TR><TD CLASS="quote">The oil pan is stamped steel. Are you going to weld the fitting in the new oil pan?</TD></TR></TABLE>
yea, i found a used B18a oil pan to replace it with, and Jeg's seems to only have aluminum weld on bungs. I was gonna have a car shop around here weld the fitting on the pan i'm picking up today
Old Jul 30, 2007 | 04:50 AM
Mikey3000's Avatar
you can't weld aluminum and steel together. you need to find a steel bung.
Old Jul 30, 2007 | 11:16 AM
blackeg's Avatar
Default Re: Can oil return bung be aluminum, or need steel?? (Mikey3000)
sure you can weld aluminum to steel ....jb weld lol.
no seriously ive jbwelded all my bungs for the past 4 years and never had serious issues
Old Jul 30, 2007 | 11:23 AM
Kyle R's Avatar
Default Re: Can oil return bung be aluminum, or need steel?? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">sure you can weld aluminum to steel ....jb weld lol.
Old Jul 30, 2007 | 11:46 AM
BDogggUT34's Avatar
no seriously ive jbwelded all my bungs for the past 4 years and never had serious issues</TD></TR></TABLE>
you know i thought about that, but i couldnt do it. Jeg's ended up having a steel one at the store and i'm having Slowmotion Motorsports weld it on. Its funny, Midas and Tuffy won't weld on a return bung because "they can't check for leaks". I've never heard of shops not being able to do simple welds.
Old Jul 30, 2007 | 12:03 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDogggUT34 &raquo;</TD></TR><TR><TD CLASS="quote">
you know i thought about that, but i couldnt do it. Jeg's ended up having a steel one at the store and i'm having Slowmotion Motorsports weld it on. Its funny, Midas and Tuffy won't weld on a return bung because "they can't check for leaks". I've never heard of shops not being able to do simple welds. </TD></TR></TABLE>
you prolly don't want those shops doing it anyway, they don't know wtf they're doing.
viper_boy403
Welding / Fabrication
May 24, 2010 07:51 PM
skiwithcars
Jun 29, 2006 01:38 PM
Stewie
Nov 9, 2005 08:38 AM
Sinner
Oct 8, 2004 09:21 AM
Layziebtnh055
May 16, 2004 10:09 AM
