Bolt on vs. welded, resonator and catalytic conv?
Old Jul 29, 2007 | 09:11 PM
jorge59la's Avatar
Default Bolt on vs. welded, resonator and catalytic conv?
I have a bolt on resonator and catalytic converter and when i accelerate i can hear an exhaust leak but not sure from where but it sound like it's coming from under the car not the bay. I checked it for cracks and there are none.
Does anyone reccomend replacing them with weld-on's?
Is welding more efficient than bolt on?
Old Jul 29, 2007 | 09:15 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: Bolt on vs. welded, resonator and catalytic conv? (jorge59la)
im thinking a gasket is leaking like on my gsr its a bolt on (greddy) and a gasket was mest up either replace it but i put honda bond and doesnt leak anymore
Old Jul 29, 2007 | 09:21 PM
jorge59la's Avatar
Default Re: Bolt on vs. welded, resonator and catalytic conv? (DOHCgarage919)
where do i find this Honda bond?
Old Jul 29, 2007 | 10:19 PM
sickofitall1113's Avatar
aftermarket exhaust items always have a problem with leaks and whisp noises and whirring noises. its very aggravating. make sure all the gaskets are new and the bolts are tightened down and beyond that its all mickey mousing it up yourself with wrap or cement or something that can stop it. if you weld it on you will have to CUT it off if you ever have to take it off. if you can avoid that your better off.
Old Jul 30, 2007 | 06:36 AM
jorge59la's Avatar
Default Re: (sickofitall1113)
thanks. where can i get gasket's for the exhaust, and also the Honda bond or any other heat resistant bond.
will this work:
http://www.bondo-online.com/ca...r=759 or this one
http://www.bondo-online.com/ca...r=735
Old Jul 30, 2007 | 09:11 AM
goota's Avatar
Hondabond is sold at any acura or honda dealership, usually like 12-13 bucks. OEM is the way to go.
dth0ng69
Jul 18, 2009 10:38 PM
StrangerWitCandy
Feb 27, 2006 07:58 PM
speedymon
Oct 17, 2003 02:04 AM
xjohnx
20
Sep 10, 2002 01:38 PM
xjohnx
Sep 9, 2002 06:57 PM
