throttle cable and exhaust 02 sensor
sup everyone. I just got done putting in a JDM integra LS obd1 engine in a 92 civic. My problem is the throttle cable is so long and doesnt fit the throttle body of the integras. Which year throttle cable or aftermarket company do I have to get the correct one for the JDM integra LS obd1? Also, my civic 02 sensor was located on the exhaust manifold, but after the swap the 02 sensor is located on the A-pipe (the one right after manifold) so the wire isnt long enuff. Is there an aftermarket manifold that has a 02 sensor access hole, or do I just get the 02 sensor and just make it longer, and if so, how much gauge? Whats a good exhaust system for these hybrids. I want them to be good flow with like stock sound. Thanks for reading, hybrid experts, where ya'll at?!
btw, the a pipe and the exhaust manifold spokes doesnt line up. I got em from jdm but im plannin on gettin a new exhaust soon anyways, so which year and company exhaust is recommended for a jdm integra ls obd1? i just wanna make sure the pipes line up and routes correctly. thanks again
you can get an LS throttle cable from the dealer for like $20, you can move the O2 wires by seperating them from harness and they will reach with out cutting or splicing. I think rywire also sells a extension for the O2 if you don't want seperate them
gl
gl
